.comhave a dell inspiron mini.
  • 69 Answers
Try pressing F8 while it boots up, before windows starts loading. That may allow you to choose how to boot.
Posted on May 17, 2011
How to get off safe mode
Step 1
Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option.
Step 2
This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the corners of the screen.
Step 3
If the system keeps on rebooting on Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine.
Step 4
During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System.
Step 5
If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option.
Step 6
Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window.
Step 7
Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode.
Step 8
If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option.
Step 9
From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option.
Step 10
Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode.
Aug 11, 2014 | Dell Inspiron 570 Mt Desktop Computer
Beeps after turning it on
First i will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues
After that start pc in safe mode, normally Pressing F8 key when windows starts up
Click start>Run.. Type msconfig>enter>Start Up. Uncheck the boxes for the programs that you think you may not use often
Open task manager and close any unnecessary processes running in background
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files, fix registry and windows errors.
Hopefully It will help you
Jul 01, 2013 | Dell Inspiron Mini 10 Notebook
My dell is slow
First run your laptop in safe mode to enter safe mode press f8 on start up if you feel the difference in safe mode means post again
Jul 10, 2012 | Dell Inspiron Mini Nickelodeon PC Notebook
Dell mini inspiron mini won't shut down
Force off by pressing the power button for 10 seconds or more. Boot into safe mode, type msconfig in the run line, disable everything that starts. Restart normally, re-enable each program untill you find the one giving trouble.
Aug 30, 2011 | Dell Inspiron Mini 10 Notebook
I'm running XP on my Inspiron 6000. It's had problems booting when several USB devices are attached (mouse, camera, keyboard, etc). Lately it will not display the windows menu after startup...it goes...
Hi. When you get to the point of having the Task Manager open, click on "New Task" and ty this in : explorer.exe
After which, press enter and see if the start menu comes up. Also try this in safe mode if it does not work in normal mode.
If it also fails in safe mode, that means your Windows is badly corrupted and the only way to get back to normal is to reformat the computer. Cheers!
Feb 12, 2011 | Dell Inspiron 6000 Notebook
When I turn my mini on, I get to the Windows welcome screen and it stops there. Is there anything I can do?
Try booting the laptop up in safe mode. Upon booting up press the F8 key until it opens up an option for safe mode. If you then do get the laptop to load up to windows go into the My Computer and right click on the hard drice icon and go down to properties. You will then click on the Tools tab and then run the Check Disk option. It will ask you to reboot the laptop so it can run the check disk. Hopefully this will fix the issue. If for some reason it doesnt go back into safe mode and scan your laptop for any possible infections with your anti virus.
Best of luck...
Have a Happy and Safe Holiday Season..
Dec 01, 2010 | Dell Inspiron Mini 9 Notebook
System is running slow and will not open programmes ie microsoft launcer? Laptop was working fine last night, no software as been instaled
To check what is going on with your computer do some tests.
1)Open task manager and check which program is taking more memory and CPU
2)Start operating system in safe mode and check the performance. (To start in safe mode press f8 while booting). If it works fine in safe mode then some program is causing issue.
3)Update your anti virus program and scan your system
Apr 12, 2010 | Dell Inspiron Mini 10 Notebook
My dell mini is stuck on welcome screen
Once you reboot, press the F8 key and boot into safe mode.
Once in safe mode, allow it to finish booting and then reboot the computer as you would normally.
This should now allow you to boot correctly into your XP.
Good luck
-Carlos:
Jan 26, 2010 | Dell Inspiron Mini 10 Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
