Question about Peg Perego Vespa Scooter
Stupid question... what motor oil (2stroke etc) do I use for my vespa px 125. thank you
  • Peg Perego Master
  • 706 Answers
It is better to spend a little more on 2T synthetic oil for less fume..
Stupid question... what motor oil - e9e3ed2d-23a6-417d-9651-f378856a56c9.jpg
Posted on Sep 28, 2014
  • 41 Answers
Hi, Use any quality brand of gearbox oil in the ST 90 gear oil (SAE 30 motor oil) range. Recommended change period is about 3000 miles. Personally I use Rock Oil as I have yet to have a problem and don't know anyone who has when using it.
Posted on Jun 21, 2011
My px 125 keeps cutting out.@
Hi, Neil and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Air/fuel mixture screw improperly adjusted.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked, loosen gas cap and go for a test ride.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Petcock clogged or damaged.
20. Lean angle switch is faulty or needs adjustment.
21. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.scootercentral.net/forums/viewtopic.php?t=18173 Px 125 keeps cutting out Help Modern Vespa Forum Two Stroke Smoke Forums...
VESPA PX 125 150 euro 2 Workshop Manual
Vespa Parts Vespa Spares Vespa Genuine Parts
VESPA PX 125 T5 Operation And Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 16, 2017 | 2007 Vespa PX 125
How to decrease the exhaust sound of Vespa PX150
Hi, Saleh that all depends on your current muffler if it's a stock OEM muffler that is in excellent condition then you would have to seek the advice of a muffler expert to fabricate something for you but if it has rusted holes or has a broken baffle or you have an aftermarket performance muffler installed then a new OEM muffler would quiet down the offending noise..
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Vespa PX 150 exhaust question
Exhaust BGM PRO BigBox TOURING BBT Vespa PX80 PX125 PX150 Sprint GT GTR...
VESPA PX 150 USA Workshop Manual
PartsSchematicP PX PXE STELLA 125 150 200
VESPA 150 Operation And Maintenance
Apr 04, 2017 | 2005 Vespa PX 150
Vespa px200 won't start
1) did you pull the choke (under fuel tap) ?
2) did you fill gasoline (+ 2% oil mix)?
3) if that does not help get a new spark plug
4) push-start the Vespa in 2nd gear with clutch pulled and let the clutch go after you reach a certain speed (easier downhill)
vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-0.jpg vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-2.jpg vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-5.jpg
Apr 19, 2013 | 2005 Vespa PX 125
Rear incadicater have stopped working on vespa px 125
The electric connectors of the rear blinkers are on the front bottom of the side panels and need to be clean blank metal (sandpaper) and put in the hole very tightly - use also some W-40 contact spray
-see photos
rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-0.jpg rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-2.jpg
Jul 19, 2012 | 2005 Vespa PX 125
I have just bought a 1978 Vespa 125 px I can't get leaded petrol what can I use ?
The old PX from 1977-1981 need a 2% 2T Oil mixture in the Petrol or it will be broken in an instant....!
The mix should always be 2% oil = ratio 1:50
for 1 Gallon Petrol = 2,6 oz oil
(1 liter =20ml / for 5 liter =100ml of 2stroke oil)
- you better get an oil measuring jug to be sure -see photo
leaded petrl is not needed
Jul 18, 2012 | Peg Perego Vespa Scooter
What is the right 2stroke oil mix for a Vespa 150 Super 1962?
the mix should always be only 2% oil = ratio 1:50
for 1 liter =20ml & for 5 liter =100ml of 2stroke oil
- you better get an oil measuring jug to be sure:
Jun 20, 2012 | Vespa S Motorcycles
Gears clunk when change on vespa px 125
don't worry -the clunk noise is typical when changing gears on a Vespa 125 PX
- it is due to a very old fashioned construction in the gearbox (1940ies) see pictures:
you have to get used to that or change to a newer automatic type Vespa....
May 22, 2012 | 2005 Vespa PX 125
I have just bought a 1988 vespa px 125 under the seat there is 2 holes one for the petrol and one that says oil ive put 2 stroke oil in the oil tank and petrol in the petrol tank today i hit 50 and the...
older Vespas without separate Oil-tanks need a premix of 1:50 oil in the gasoline - but yours is an automatic oil-mixer type.
check the oil-level-glass under the seat near the choke.
it must be full of oil - the oil tank can hold about 1 liter of 2-stroke oil. How much oil did you fill in?
Probably the previous owner removed the oil supply tube and filled always an oil-gasoline premix. You better ask him about it. If the tube was removed then there was no oil supplied to your engine and it got stuck and the engine bearings are blown.
Apr 07, 2012 | 2011 Vespa GTS 125
How do i replace brake pads on vespa px 125
if you have experience as a mechanic you can do it by yourself, but otherwise it is better to have it done by a pro, as the brakes are a main safety item....
How to replace Vespa drum brakes NYC Scootering New York City scooter news...
replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-0.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-2.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-5.jpg
Feb 23, 2012 | 2011 Vespa PX 125
Petrol,oil mixture for 1969 vespa 150 sprint with a px 125 motor
2% as most Vespas. Some folk like to add a bit more for a tuned engine.
Nov 23, 2010 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
333 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
