Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Where can I buy a remote sensor for the Homedics SS5000? The one I have doesn't work.
How do I get a replacement remote sensor? - Homedics Ss-5010 Soundspa Premier Am/Fm Clock Radio
Hi Wayne.
i can not find one on the internet at the moment but you could try ebay.
Nov 03, 2017 | Homedics Audio Players & Recorders
The reduce volume key on my GE remote to my GE (model 20GT360) TV doesn't work. Can I buy a new remote or get a universal remote? I don't know the code.
If you are certain that your remote is defective, consider buying a GE universal remote as a replacement. The instructions that come with the replacement remote will tell you how to get it working with your TV
Feb 05, 2013 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
94 full size blazer keyless remote doesn't work.
Does the spare remote work? Have you tried to reprogram it? These remotes are very cheaply made and prone to key pad failure. To program the remote click this LINK, if that doesn't work buy anew one on eBay for cheap.
Jun 13, 2012 | Cars & Trucks
My original remote is not working. I bought a universal remote and it doesn't work either. Can't get a remote to work on the tv
Hello
The remote sensor inside the circuit board of your TV is faulty. It is the component that receives the infrared signals of the remote control. If this component go faulty, no remote control will go with the TV. This component can be located on the front panel board of the TV just behind the infrared sensor window at the front. You have to open your TV to locate this component. It is a three terminal component, look brownish black in colour. The sample picture of it has attached here. It is very cheap to buy, and can be bought from most of the electronic sparepart shops at your town. If you have a concept of soldering and resoldering, you can replace this component yourself at home OK.
Oct 02, 2011 | Symphonic ST420FF 20" TV
Mistakenly we kept the homedics massage system in 230v instead of 120v voltage. It's not working now. Is there a way to fix it.
if your Homedics Back Massagers has a product warranty you should bring where you buy it..
if has to warranty you can try some techie sollution.
if it has an adaptor that connected to massagers you can change it with the same specs.
most adaptor has a label that indicates volts amphere and connector polarity..you can buy same specs at ebay.. or search some electronic store.
if it has no adaptor you have to dismantle your massager and search the fuse or circuit connected to
the ac line.. good luck....
Aug 21, 2011 | Homedics Health & Beauty
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
Pansonic NV-HS960 will not accept signal from Remote control
Obvious things first check the battery, check nothing is blocking the signal area. If still no look try another remote, you might have to buy a cheap universal one. If that doesn't work then the remote sensor in the VCR has a fault in it.
May 26, 2011 | Panasonic Televison & Video
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
273 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
