Question about Radio Communications
Purchased CB radio kit from Maplin with TTI brand CB and mag mount aerial in kit. Installed new CB's using a cigarette lighter adapter which plugs into lighter. CB comes on fine and this appears to be working okay. However, unable to pick up any CB chat. Drove around the local area but, not a murmer. I appreciate that this may not be the best bit of kit in the world but driving past multiple lorries with CB aerials on, figured i would pick up some chatter on channel 19. Any ideas/recommendations? Has the squelch set to Auto but, have tried manually but no greater success.
    Champion:
  • 219 Answers
Sounds like you have a bad antenna.Altough it might be new doesn't mean anything I have customer come thur my shop with new antennas that they bought mostly from truck stops that have the same problem most of the time they have no ground,although its a magnet mount it can still read bad,take it to an honest shop and let them help you.
Posted on Jul 10, 2011
Where is the cigarette lighter fuse located in a 97 buick century?
GOOGLE is your friend! Open up Google then search for this exact phrase (without the quotes)
"97 buick century cigarette lighter fuse location"
Aug 05, 2014 | TRUCKSPEC TSP-311 12-Volt 2 Outlet Fused...
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Hello, i had my mcb-40 mounted in my jeep and it worked well. i switched it over to my new truck and now it will not turn on. no channel displayed, no sound. i have the power and ground both conected...
First make sure you are grounded well. Second do you have an inline fuse on your power wire? If so check that it did not blow. Even if it looks good throw another 3 amp fuse in to make sure. Also make sure your power source is actually hot and make sure the fuse in the panel fuse box for your power source has not blown. Also are you using the cigarette lighter? If so make sure the fuse to the cigarette lighter has not blown. Last you can try a new power wire. If you try all of these to no avail you more than likely have a radio issue. Good luck.
Mar 04, 2011 | Maxon MCB-40 40-Channels Handheld CB Radio
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Intall a cigarette lighter adapter to a CB radio
are you asking can you. If so yes it's just two wires
Jul 09, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Transmitting problem on motorcycle
  • Make sure you run the CB directly to the battery. What you are hearing is the alternator whining. Even then sometimes a low pass filter may be necessary. Make sure the chassis of your CB is grounded with a copper braid strap too.
  • Hope this helps.
Apr 27, 2009 | Midland 75-822 40-Channels Handheld CB...
Radio Communications Logo
109 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
