Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 printer
A black line is appearing down the side of the paper when we print a document any ideas what we can do
  • 43 Answers
Black smear down page (either left or right) is caused by fuser. To check simply remove the toner cartridge, remove the 2 screws holding the fuser caution plate, gently pry the right side and look at fuser film for dammage. DO NOT FORCE the cover off the unit as it will break and then you'll need a fuser assy.
Posted on Jan 23, 2009
I had the same problem, and was solved by replacing the cartridge. We recycle cartridges, and it was time to throw some of them out.
Posted on Feb 09, 2009
I have HP laserjet 3055 when i use a scaner i see: There is no paper in the document feeder. What this?
Remove adf input tray,lift adf unit cover observe black sensor flag fixed in side of cover this flag play in to the sensor locate the sensor clean with small brush,care fully observe the sensor location, fix back, check.
Sep 21, 2011 | HP LaserJet 3055 All-In-One Printer
I get a black line down the left side of the page when a document is printed
Either the black cartridge is bad or the fuser roller is bad. Pull out the black cartridge and gently pull down the flap that runs across the cartridge. Look at the drum inside. If you don't see a line running around the drum or a clump of toner on the drum where the black line appears on the paper, your problem is a bad fuser.
Aug 05, 2011 | HP Laserjet Cp2025n Printer
Hp 3055 my problem is when i take print paper one side coming complete black
Hi
This your cartridge problem change the as soon your printer cartridge and buy the genuine cartridge in Hp service center.
Jun 01, 2011 | HP LaserJet 3055 All-In-One Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black line down side of copy
Pull open the document feeder and clean off the scanner glass.
Jun 08, 2009 | HP LaserJet 3055 All-In-One Printer
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Print is missing along a one inch width patch for the entire lengh of mdocument
try a new toner cartridge
if it doesn't fix your problem then you willneed a new fuser
it is probably delaminated
Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
266 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
