Question about ASUS F5Z Laptop Charger (1300745LMD0008111)
Hello, I have Asus f5z, video card is ATI Mobility Radeon HD 3200. Original Windows Vista, automatic updates always On. And suddenly began go error, screen blinks, and shows "ati stopped responding and sucsesfuy recovered". Later it began stop working with blue screen and restarts. Then I formated disk, instaled Windows 7, newest drivers, but it doesn't solved the problem. Notebook anyway goes with bluescreen and restarts, then I turn it on Safe mode, disable graphic card driver, then restart and it works without restarting, but without video card driver. When I enable it Notebook goes bluescreen and restarts. When disable ATI HD 3200 driver it works good, and I can't enable graphic driver. Pls Help What to do.
  • tremneriai May 18, 2011
    I installed that newest driver. Enabled display card driver. Computer starts seems fine. But when I begin browse internet via IE9 or Mozilla 3.6, computer freezes or goes bluescreen and restarts again. When disable graphic card driver computer runs without restarting itself.
    I don't know maybe it's something about overcloking or gpu and mem frequency.
    No I didn't do overclock or anything with frequency ever.
    I'm trying to find solution too. I read lots of forums, and that's what I did:
    uninstalled ATI driver, booted in safe mode and then ran driver sweeper, then restarted in normal mode, installed old 2008 yers CCC driver for ATI. And now computers doesn't go BSOD, just couple times blinked LCD and everythig returned with message "ATI Radeon driver stopped working and sucsesfully recovered". So that's all with ATI drivers I think.
    Scholar:
  • 35 Answers
This could either be a problem with the graphics driver, or a problem with the graphics card itself.
Try once more downloading the latest version of the driver from here: http://support.amd.com/us/gpudownload/windows/Pages/radeonmob_win7-32.aspx and installing it while your computer is running without the graphics driver turned on. Then try re-enabling the graphics driver to see if the updated driver solved the problem.
If updating the driver doesn't work, it's almost certainly a problem with the laptop's video card. If this is the case, you'll want to have it looked at by a professional, or contact Asus support directly to see if they can help you resolve the issue.
Hope this is helpful!
Posted on May 17, 2011
  • Kylen Wiggin
    Kylen Wiggin May 18, 2011
    If you're overclocking anything, or have changed the memory frequency settings, I would definitely advise returning both to their defaults and trying to run that way. If you're overclocking your GPU, that could definitely be causing the problem - it might not be damaged after all.
    Try returning all settings to their defaults and see if it will run properly. It definitely sounds like the problem is in the GPU - either something is not set correctly or it is damaged.
    Hope that helps!
  • Kylen Wiggin
    Kylen Wiggin May 19, 2011
    It could be the drivers, but the current Catalyst drivers are fairly stable. I use an ATI Mobility card in my laptop as well, and I've had no driver problems for the past year or so. I'm inclined to think that there might be a problem with your GPU, but it's difficult to tell for certain without looking at it. My best recommendation would be to have a professional test the GPU to see if it's at all functional.
How do I find working XP video card drivers for a Gateway TA7/ Viper-SR laptop/tablet?
are you sure about the driver/chip? You may need to double check - was this an upgrade/ change of OS from a Vista machine? Or could it be direct x? read below.... otherwise I have no idea sorry ATI Mobility Radeon HD 2300 csm_ati_radeon_chip_05_e8206cf22f.jpgThe Mobility Radeon HD 2300 graphic card for laptops is the successor of the X1300 and supports only DirectX9 (according the informations of the AMD homepage). The performance shall be somewhat above the X1300 and therefore present average or worse game performance. AMD / ATI tells that the relation of performance/Watt has been improved. Rumours tell that the chip is only a renamed X1300 / X1350 video chip.
A difference to the X2300 are the amplified video options (UVD).
The HD 2300 graphic processor is certified for Windows Vista and supports the Windows Aero Glass Interface.
Manufacturer ATI Mobility Radeon HD 2000 Series Mobility Radeon HD 2300 4/2 cores @ 480 MHz 128 Bit @ 400 MHz Codename M71 Architecture RV5xx Pipelines 4 / 2 Pixel- / Vertexshader Core Speed * 480 MHz Memory Speed * 400 MHz Memory Bus Width 128 Bit Memory Type DDR1/DDR2/GDDR3 Shared Memory no
HyperMemory wird unterst?tzt DirectX DirectX 9c, Shader 3.0 Transistors 115 Million technology 90 nm Features 90nm manufacturing process, PCI Express X16 Interrace, PowerPlay 6.0, Avivo Video architecture (MPEG-2, MPEG-4, DivX, WMV9, VC-1 acceleration), 64-bit floating point HDR, Ultra-Threaded Shader Engine, OpenGL 2.0 Date of Announcement Link to Manufacturer Page http://ati.amd.com/products/MobilityRade...
Nov 25, 2014 | Gateway Ta7 E-295 Laptop Tablet, Core 2...
Im trying to update my Mobility Radeon HD 4000 series driver but it saying "ATI Catalyst Mobility cannot be downloaded due to incompatible hardware/software on your computer."
Sounds like your trying to download the wrong driver for your operating system. Double check that you're selecting the correct drivers for your operating system.
Jan 24, 2011 | ATI RADEON HD 4650, PCI Express Video...
My sound card was accidently deleted , I was wondering what kind I need so I can re install it
follow this dell link
  • http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R91865&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=119690
How to Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700... This step-by-step guide describers how to obtain and install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP drivers for Windows.
1. Define your Dell Notebook device model.
2. Define your operating system to install your Dell Notebook device. Note: Update Drivers in Win Vista
3. Browse Notebook Drivers.
4. Find Dell Notebook Drivers.
5. Select Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
6. Download Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Jun 05, 2010 | Dell Inspiron 9200 Notebook
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Jul 05, 2009 | Dell RADEON X600, (128 MB) Graphic Card
ATI mobility radeon 9200 on windows 7
I am using a HP Compaq Presario X1000 with a ATI Mobility Radeon 9200 display.
I have recently installed the Windows 7 RTM and tried various display drivers with no good results.
I am now using the driver from ftp.asus.com.tw/Pub/asus/nb/A4D/VGA_XP_2K_060102.zip
At first I unzipped the folder and run the setup program inside but it was not successful.
Then I go to the Device Manager, choose the display driver and choose "Update Driver"->"Browse my computer for driver software"->"Let me pick from a list of device drivers on my computer"->"Have Disk"->"Browse"
click to the subfolder inside your extracted folder and find the folder named "2KXP_INF" and choose the inf files there and click "OK"
A list of device is displayed and I choose "ATI MOBILITY RADEON 9200"
the computer will install the driver and ask to restart the computer.
After restarting the computer my display was automatically set to 1680x1050, I found the following driver was installed:
Driver Provider: ATI Technologies Inc.
Driver Date: 1/19/2005
Driver Version: 6.14.10.6512
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
I went on to test Suspend and Hibernate and they WORKED!
I have not tried this on Vista as I was running XP and Ubuntu in the last few years.
May 26, 2009 | ATI RADEON 9200SE Graphic Card
Unable to install Geforce 8400 Video Card
try downloading the drivers from www.nvidia.com and install the latest drivers
Apr 30, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Inexpensive Graphics Card for Notebook Video Editing?
Definetly the ati one. 120 stream processors is really good and it has
direct x10.
Jan 08, 2009 | HP Pavilion dv6000z Notebook
Driver for ATI Radeon HD 2300
ati.com is always the best place to get drivers for ati cards. i couldnt find them on there so here is another place...
http://www.omegadrivers.net/ati_winxp.php
Jan 22, 2008 | ATI Mobility RADEON Graphic Card
Drivers required for ATI mobility radeon X2300 video card
I have Sony Vaio VGN-CR26GN/B Laptop.I have Intel processor and ATI Mobility Radeon X2300 graphic card.I need NEW UPDATED drivers for ATI Mobility Radeon X2300 Graphic card.OLD Drivers are causing performance issues.There are no new drivers for ATI MOBILITY RADEON X2300 graphic card on ATI.com and AMD website and other websites.I have searched the web but the result is nothing.I have also searched Sony website for drivers but they have not updated for a longtime.Please PLEASE Give me the link for NEW Updated drivers for this Graphic card Model:ATI Mobility Radeon X2300 on my email.ThankYou
Jan 03, 2008 | ATI Mobility RADEON Graphic Card
ATI Radeon mobility Graphics Card 9200 Drivers for VISTA
http://www.opendrivers.com/driver/240370/ati-radeon-graphics-card-driver-catalyst-7.11-windows-vista-x32-english-free-download.html
Dec 03, 2007 | ATI Mobility RADEON Graphic Card
ASUS F5Z Laptop Charger (1300745LMD0008111) Logo
430 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
