Question about Breville BKE820XL Electric Kettle
I have a Breville Kettle BKE 820XL The switch is lit, but does not turn red, so the kettle will not turn on.
  • Anne-Louise Watts May 17, 2011
    My Breville Kettle BKE820XL will not turn on to heat.
    The switch lights up, but does not turnon the kettle
    President:
  • 2,187 Answers
This could be just an issue with the contacts of the base not meeting the contacts of the kettle and no power is delivered. Cleaning may help it. This could also be an issue with the switch. Internally the switch completes the circuit by 'bridging' the conductors found inside. It could be the conductors are not touching each other. If refitting the switch will not help yo may have to replace it. If you have a continuity tester you may check continuity of the circuit from the end of the coil down to its corresponding terminal on the pot while the switch is at the 'on' position. Same goes with the other to check if the switch is good. Test also continuity from the switch to the plug to test of contact between the kettle and base is good.
Posted on May 17, 2011
  • Breville Master
  • 19,396 Answers
Hi.
The switch does not get red because reach of adequate temperature is not detected. The problem is either thermostat or element. Both parts are tested using a multimeter set on Ohms to read impedance. if the part reads open, then it must be replaced.
Problem will be locating the part.
First call Breville and find out repair price and warranty status.
Here Breville USA:Breville . See also: Parts ' Breville
Here Australia:Breville
UK:Breville
If the unit is out of warranty call EReplacementParts, they sell parts and do repair. number is 866-802-6383
Here a disassembly diagram.
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
How do I improve the electrical connection between the base and kettle of my Breville Ikon?
The kettle should be considered unsafe for continued use. It has failed as the parts used are not suitably rated for the load they carry. The only safe option is to replace the kettle with a new one.
Jul 15, 2014 | Breville Kitchen Appliances - Others
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Feb 09, 2009 | Breville Kitchen Appliances - Others
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Sep 15, 2008 | Breville Kitchen Appliances - Others
Light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Breville BKE820XL Electric Kettle Logo
514 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
