Question about Miele M638EC 1500 Watts Convection / Microwave Oven
Locking device keeps breaking on my Miele Combination Micro Was this a bad micro to buy? Have the oven as well thats great. As this is fitted into my unit I am now having a problem finding another combi micro that will fit in
H 5040 BM has sparking/flashing coming from grill connection inside top of oven whilst microwave is in use causing this connector to glow red
take it in for repair as the connection is shorting out from the micro waves
get a quote as most repairs are more than the replacement cost
Mar 22, 2016 | Miele Microwave Ovens
My oven suddenly stopped working
Most microwave ovens have up to 4 micro switches in the door latch, it's a safety interlock. These can go bad, and cause the oven to not function.
Micro switches are pretty inexpensive, and can be replaced. You need to open the oven, and then identify exactly which micro switches you need. Both my current microwave ovens have done this, and I've replaced the bad switches. They work fine now.
Jul 15, 2015 | Microwave Ovens
Fuse is blowing of
door (micro)switch is bad... 8 bucks each replace them both
Apr 07, 2014 | Kenmore 63792 Microwave Oven
Miele M625 lightbulb replacement
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Often on a unit whose bulb is not meant to be replaced by the customer, the light is located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Dec 11, 2012 | Miele M625EG Convection Microwave Oven
We have a emmerson micro and the turn table cluncks
Problem fixed. Called number on micro and they were great in fixing the problem.
Oct 28, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Jun 21, 2009 | Emerson Microwave Ovens
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
Miele M638EC 1500 Watts Convection / Microwave Oven Logo
27 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
