Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I wish to use the seagate hardrive to back up music on a brennan jb7 i am having problems formatting the seagate to fat32
  • 621 Answers
Im not sure why you want Fat32 but with that old file system a partitition cant be larger than 32GB otherwise it wont let you format with Fat32. You can create as many partitions as you like maybe have some Fat32 and some NTFS if you like. Just typy in disk management where you normally do a search or run with XP and that will let you organise all of your partitions. Cheers and please vote
Posted on May 18, 2011
Brennan JB7 wont switch on after we had a power cut
The power supply may have a voltage missing or have gone bad. Worse is the motherboard fried. If you used a surge protector it may have done it's job. There are sacrificial parts called MOV's inside that sometimes explode or just open internally. That may need to be replaced.
Aug 08, 2015 | Power Computers & Internet
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
Jul 17, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
How to change format to fat32
This requires a format of the drive, make sure you have your data backed up off the drive.
Right click My Computer, select Manage. Select Disk Management. Find the drive letter assigned to the external drive. Right click on it, select FORMAT, then select FAT32 as the file format.
Jan 10, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My alpine ida-x100 can read flash drives but not a portable hard drive. why? can I make it work?
The hard drive must be formatted in FAT 16 or 32 for the Alpine to recognise its there. It came pre-formatted in NTFS.This is an easy fix once you know the problem. Just save your data/music onto another drive.Then use a program like easeus partition master (free download) to reformat the external drive in FAT32. Move your music/data back onto the drive and the Alpine will now see the drive and all your music. As a matter of interest some people say you cant format a drive bigger than 32Gb in FAT32, but I had no problem with the above method on a seagate 500Gb drive. Also apparently some head units cant deliver enough power to spin up an external usb powered drive, but again I had no problems with the above combination
Aug 04, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Ps3 not formating 500gb internal new hard drive?
Hi Eric,
First you will need to connect the hard drive to your computer or a friends, either using a hard drive enclosure or cable
Then you need to format the drive into fat32 format (full format recommended , not quick format)
Then put it back into your ps3 and have a usb flash drive with the latest ps3 software loaded
then you will be able to format the drive and load the ps3 os
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
148 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
