Question about HP OfficeJet 7310 All-In-One InkJet Printer
My printer does not prints continuously the printing ink was refilled recently. what could i do? pls need some help
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
It could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA.
Posted on May 17, 2011
Testimonial: "it worked thank you and fixya for solving it."
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
f you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Office Equipment & Supplies
How do i increase the tone of the printer without the need to reset the ink level?
You need to max the picture quality in printer option.
There should be option for printing quality......
Some of the HP cartridges offer cheaper price....with more printing pages.
(after you get a prints, will realize printing tone is much lighter, that's why you get more prints)
If you are refiller, try better ink....
If you would like to save money, try refill kit by "ROADINK".
And will see how easy ink refill can be done.">
Apr 26, 2011 | Office Equipment & Supplies
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Wont print cyan
Install the correct driver for your system.
Find them here:
http://software.canon-europe.com/
I searched this for you. Pls leave a good rating!
Oct 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Black ink will not print
The ink on the print head is dry and it is preventing it from printing.
I do my own refill so I buy a refill kit, in it, has 3 bottle of inks and a bottle of cleaning solution. The cleaning solution I use to clean the head.
A place that refill in should carry some kind of a cleaning solution that you can use.
I hope this help you
Mar 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP180
There is no way to reset the ink levels on the new canon cartridges. you need to turn off the ink status monitor :(
You'll know it's time to refill again when your printing starts to fade, streak, or discolor.
Aug 24, 2008 | Canon MP610 Photo All-In-One Printer
PRINTER STOP PRINTING
Not sure what you mean. If you used OEM cartridges, then you should have no problem. If you refilled them, then you can still print but you will not have access to an ink monitor. In order to print without the ink monitor, you printer will ask you some questions. I'm not sure what they will ask but I think you can just figure that out yourself. The last question I think you say Ok to continue printing regardless of the ink monitor. Good luck.
Jul 30, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
162 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
