Question about Brother ML-100 Typewriter
Striker Sticking When Erasing. Brother ML100 Typewriter
Originally, on this Brothers ML100 Typewriter, the striker simply would not move. You told me about trash in gears, cam and solenoid. After I cleaned and checked everything, the carriage would travel left, jam, and beep alarm. Second, you told me about the limit reference switch on keyboard, which fixed the travel problem. And now, the striker works fine (versus originally, not moving, at all), till I hit the erase key. Striker goes, and stays forward, jammed into the daisy wheel.
Several times, it typed fine, till I hit the erase key. The only way I can get the striker to move back to its resting place is to take top off, exposing the cam and gears, roll them some until the pressure comes off the striker and it moves freely again. Can you give me any help on this? Thank you
  • eddie27970 Sep 18, 2008
    Upstateos. sorry it has been a while getting back to you. ML100 still messing up, ...sometimes. Works a couple day, then striker stays stuck forward.
    But, found the problem! The spring was not in the right place. Took the top cover off (holding erase ribbon), tricked the return switch, and then watched the gears. Noticed, when hitting erase, it pushed the ribbons upwards, and held everything down the rest of the time. So, kept playing with spring, till I realized you put spring on "after" everything back in place. I was trying to put long tab of spring under erase ribbon cover when reassembling. This time I put all the pieces back, first, and then put on spring, and noticed it fit nicely under the adjusting tab. Now ribbon assembly jumps up and down like it is supposed to, and the striker is actually moving faster. The way I had it before, aparently had the gears in a bind, slowing the striker up, and causing it to not reset after every stroke. Thanks again for all your help. (Secretaries think it was me, not you, that figured it out. ha ha)
    You know, it would have been good to find a detailed picture of how all those parts went back together.
    Sergeant:
  • 329 Answers
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Posted on Aug 28, 2008
Language for brothers typewriter
If it is a standard typewriter, you have a set of long bars or levers, each with a letter of the alphabet cast onto the tip.
To change that language, you will need to replace the whole set of striker bars or levers to the correct language.
If your machine has a ball with the language letters on it, you will need to replace the ball.
If this is a Brother computer, you will need to contact the Brother company for the instructions on how to change the language.
God bless your efforts.
Jan 04, 2017 | Computers & Internet
Key striker quit working
Is it still receiving power to do the striking? Check that out!
Aug 04, 2016 | IBM Wheelwriter 6 Typewriter
Striker not working on a Brother ML 300
it could be a broken wire in the harness from the control board to the hammer
Mar 21, 2016 | Brother ML-300 Typewriter
Wheelwriter 5 - Striker not hitting printwheel
You most likely have a broken print solenoid cap. I sell them with instrucyions for 20.00 includes shipping.
DickyO
typewriterguy@att.net
Aug 20, 2015 | IBM Wheelwriter 5 Electronic typewriter P...
Typewriter is an ML100 Standard Brothers Typewriter
repost if you are still having this problem
Aug 28, 2008 | Brother ML-100 Typewriter
Striker not working. New problem. Carriage move left
Refresh me is this a Brothers. If it is the keybord has to be lock down in the clips. The carrier home switch is locateded in the keyboard not the machine frame. Chances are the cable is ok it sounds like this switch is not being it when the carrier returns home...
Aug 05, 2008 | Brother ML-100 Typewriter
Striker Not Working. New Problem, now.
One very important thing with Brothers typewriter, If the keyboard is not locked in place under the catches, it will not complete the home cycle. In other words when the carriage returns to the left it will cycle and then beep usually continually. The reason the carriage stop time switch is attaced to the keyboard not the side frame. You might look at that....Could be other problems too. keep in touch
Seems like the striker key? is not hitting hard enough - have had only a few months,
Spray degreaser that does not harm plastic, spray the hammer area and the this model also has a spring that brings hammer forward, could be going weak... Sounds more like sticky hammer.
Jul 17, 2008 | Brother GX-6750 Typewriter
Striker not working?
Cam system on most brothers cause this to strike, make sure it is free andnot binding, also the solinoid underneath the printer comes off. Look for parts in the bottom of the machine. It is repair able.
Jun 03, 2008 | Brother ML-100 Typewriter
Does not type
Throw away and purchase a Nakajima typewriter.
May 02, 2008 | Brother GX-6750 Typewriter
Brother ML-100 Typewriter Logo
173 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
