Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Pump was humming but would not start so I took the motor apart and it needed a god cleaning but I noticed that a metal ring that sit inside the motor close to the bearing on the shaft about 1'1/2" long has a wavy worp to it. Is it ment to be like that or should it be flat. Thanks please advise Pat Cortese
  • adam hudson
    adam hudson May 17, 2011
    It is meant to be like that. So that it causes more pressure to be applied evenly to the bearing.
    President:
  • Hayward Master
  • 1,378 Answers
It is a bearing spring designed to keep the shaft tight against the PE endbell so the impeller sits in the pump properly. It is suposed to be wavy and it sits in the endbell on the opposite drive end.
John
Posted on May 17, 2011
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Anthony filter system faulters after short while of running
If you have alge in your water it builds up in the filter and stopps it up rite away. You will need to take the filter apart again and hand clean it out again. but you will need to super chlorinate the water and kill all the alge before you start the pump or it will plug again. If you run it like this for any amount of time it will crush the grids, so be sure you kill all the alge.
Oct 13, 2009 | A.B.S ALADDIN GO-KIT #7 ANTHONY POOLS 2"...
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No...
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Jun 25, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Humming pump throws beaker
It's because you may have a defective starting capacitor or a stuck-up motor or pump. If you know how to check a capacitor, do so. If not try replacing the old one. If the problem still persist, try to turn the shaft with your hand. If you can't turn it. You might have a defective motor or pump bearings.
May 30, 2009 | Plumbing
I took apart to clean glass - think it is assembled wrong!
that glass( slanted one) is supported on top by the metal plate ( problably 3 inches wide) running across the top of the metal cover(covering the insulation level) the glass inserts inbetween 1 or 2 tabs in the metal support, it then lays on an angle against the metal cover( hoilding the insulation level) and is secured by the 1 in thick angled metal retainer. hope this was helpfull.
Mar 14, 2009 | KitchenAid Architect Series KEBC107KSS...
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
No power
Since this generator quit working suddenly it's likley that something is wrong with the field circuit inside. The metal surfaces you cleaned off sound like the slip rings of the rotor, there should have been 2 graphite square rods mounted on the plastic bit you took off that ride on these slip rings, they could be worn down or broken.
You'll need a good DMM to measure the resistance between the 2 slip rings (should be about 15 ohms), also measure each of the stator coils (black and white wires in the molex plug) look for an open.
Because the generator has been sitting for a couple of years it probably also hsa lost its residual magnetism, you'll need to flash the field to get it working again once all the parts are confirmed to be OK.
Oct 07, 2008 | Coleman Powermate Powermate 5000W...
Dishwasher does not cycle
Yes, you'll need to replace the motor. Though you may not need to remove the machine from under the counter.
Feb 09, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
193 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
