Question about Frigidaire Freezers
Frigidaire model #FEB798CC - double unit. Neither oven will operate. After entering "Bake" and "Temp" oven appears to be heating, but shuts down after a few minutes - both units do the same thing.
  • 358 Answers
SOURCE: HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Posted on Aug 02, 2009
SOURCE: I have a Frigidaire model
it the timer
Posted on Sep 27, 2010
  • 11800 Answers
SOURCE: Door alarm light is on
The open door alarm is triggered by the small switch that also triggers the internal lighting. This is easy to test: open the door and press the switch - on a normal one the light should go off.
This is the switch
http://www.bizrate.com/refrigerator-accessories/oid1852839097.html
And here is in the parts manual page 4 part 14
ftp://ftp.electrolux-na.com/prodinfo_pdf/stcloud/5995552030.pdf
Posted on Jun 04, 2011
  • 661 Answers
SOURCE: "Power" light off. Temp warning
Hi Dugga,
This seems to be a problem with the circuit board ,
This causes fault in it that does not allow the board to come back on or work properly sometimes if the power blinks off and back on.
You need to check if the part is under warranty , if it is , then get it replaced for free or you can buy a new board so that this problem is eradicated once for all.
This is not a new problem , there were many defective boards that were recalled by the company and replaced free of charge, probably you were left out.
Hope this helps ..:)
Posted on Aug 26, 2011
My upright frigidaire freezer won't cool. Lowest temp it goes to is 1 degree. Fan works. model number is Ffh17f7hwj
Remove back plate and check to see if evaporator is frozen over. If so, your defrost timer/heater is not working. Till repaired defrost unit completely. It will work fine till it freezes up again or you make the necessary repairs. Not hard to do just a PIA.
Sep 15, 2017 | Frigidaire Freezers
Model#LFFU17F5HWC Small amount of water on the floor at left front of unit. Temp ok 0 5 yr old unit. never happened before. any ideas.
check the door gasket seal. If it doesn't seal properly, moist room air will condense and drip on the floor.
Aug 09, 2015 | Frigidaire Freezers
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
Hi. I have just aquired an "IGNIS" chest freezer, model AFE 460/IG, class T. On the bottom right hand side of the freezer ther is a dial (from 0 to 3) which can be altered using a screwdriver...
Pretty sure that the slide is for winter and summer operation, you are rite, the 3 position is the cold level and the 3 lights (Yellow, Red, Green). the Yellow indicates a caution,"" not at temp or faulty""the Red indicates the unit is active and the Green indicates at temp and operating correct. This unit is old and not much information is available however I hope from my experience, that will help you, any further problems call Russ on 08 95230552.
DONT FORGET TO VOTE, I SUPPLY MY TIME FOR FREE TO HELP. RUSS
Mar 02, 2011 | Freezers
Where is the Adaptive Defrost Board on a Frigidaire GLHS36EEQ6?
The board is located under the freezer side of the unit. You can call Sears, as they carry your brand's parts and they will tell you exactly where it is. There are diagrams on the web too. Search for appliance parts. You'll need to enter model number here: www3.sears.com
Fridgidaire refrigerator repair in Orange County, CA
Feb 05, 2010 | Freezers
Freezers Logo
42 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
