Question about Kenmore 98702 Stacked Washer/Dryer
Water drains out the back left corner when the tub is filling. Water will not stay in drum. What could be the problem. Its a stackable Kenmore.
    Sergeant:
    Champion:
  • 257 Answers
Could be the over flow sensor tube thats attached to the side of the drum has come off or one of the drain hoses. Take the front panel off by unscrewing the 2 screws at the bottom and pushing down on the panel to unlock. From there you should be able to see with a flashlight where the water is coming from.
Posted on May 17, 2011
Stackable kenmore washer dryer
could be a clogged pump or drain hose causing the water to spin over the top
Jan 15, 2013 | Washing Machines
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Water fill not working properly
theres a over flow/check valve in either the left or right corner of the inner tub (looks like a mushroom sotr of,) perhaps this float is getting stuck, or perhaps something has gotten under it i.e. pasta chicken bone.
Nov 30, 2008 | Kenmore Dishwashers
Kenmore 98702 Stacked Washer/Dryer Logo
63 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
