Question about Poulan Garden
It will no longer go forward or reverse - Poulan Garden
  • 407 Answers
Check your drive belt.It may be broken or just slipped off the pulleys.
Posted on May 17, 2011
  • 1 more comment
  • jlakedodge May 17, 2011
    blades still turn
  • Michael Spreafico May 17, 2011
    There is another belt that moves the mower it is above the blade`s belt.
    Looks like you are right. Someone more mechanical than I looked at it and said it was the belt. Thanks
My black and hammer has no forward, but does operate in reverse
That would be Black and Decker, but what model. Generally forward and reverse are controlled by a switch near the trigger, so you can switch one-handed. You may have to repair or replace that switch, or buy a better drill. While lithium batteries are handy, the plug-in drills last so much longer than batteries, cost less, and often work better.
Jun 01, 2017 | Hammer Drills
The transmission has 190.000mi. I used a different fluid when serviced.started slipping ,& now no forward gears wrk. Has strong reverse it wrk well.
try changing the oil a few times to flush out the oil you used
What oil did you use that caused the problem and is it specific for auto transmissions
Feb 04, 2016 | Cars & Trucks
Craftsman ltx 1000 18hp tractor will no longer go forward but runs normal in reverse
First replace the drive belt. (1/2 x 82-1/4) and the V-idler pulley if plastic, Reverse doesn't load the belt as much as forward drive. The reason I suggest replacing the V-idler too is that the plastic wears heavy and the drive belt bottoms out causing slippage.
Then if it doesn't drive forward then you most likely have a bad transmission.
Nov 24, 2014 | Craftsman Garden
1994 ford ranger, No Reverse
The most common reason for no reverse in this model is either a pressure loss or broken band. The valve body gasket has gotten brittle and broken away thus losing pressure to the reverse servo or the reverse servo has had a seal fail and can't press the rear band or the rear band has broken and can no longer squeeze.
Jun 12, 2013 | Cars & Trucks
How to rewind/fast forward trough currently listening segment?
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
Jun 23, 2012 | Coby MP828 layer
I have a 99 or 2000 yamaha 250 bear tracker that pops out of forward gear sometimes when you switch from reverse to forward. How do I fix this?
That forward and reverse lever is adustable. If it's popping out - just try and adjust it to where it lengthens and is more stiff when going into reverse and forward. You can shorten or lengthen that rod that connects the piece you squeeze and pull back/forward to the mechanism on the middle gear housing. When you look - you'll see an adjustment nut. loosen it and adjust it out to where that rod is longer.
May 02, 2011 | Yamaha XS1 Motorcycles
Slides will not advamce when you push lever. It is 50 yrs old.
The KODAK Carousel 4600 was manufactured from 1981 to 2004. If the tray won't advance with the push button on the projector, but will reverse, then it is a contact problem under the handle. If it doesn't cycle in forward OR reverse, but the "SELECT" feature does work, then there is a problem with the cycle (orange) wiring or the slide-change mechanism requires an adjustment. If forward, reverse and select ALL don't work, chances are the low-voltage side of the power motor is no longer providing the required voltage. An authorized repair dealer can help you sort this out.
Oct 14, 2010 | Kodak Carousel 4600 Slide Projector
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Garden Logo
51 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
