Question about Canon PIXMA iP5300 InkJet Photo Printer
Installing printer in vista
Hi there I need some help, I have a canon pixma 1p5300 and I am tring to install it but i keep getting an error message.
When i switched the printer on the computer insalls all the drivers and it says it is ready but when i go to print there is not the option to select it from the printer list.
  • deniese Aug 14, 2008
    Hi, i had a look but it is not showing the printer as being there, could it be the port, it is set on port1, but i had a look on my other computer and it is set on usb1?.
    Just a thought
    Hi sorry, no there is not icon at all, but when i plug the printer in etc, vista says it is installing it and it is ready to use, but when you got to print the printer is not there.
  • 320 Answers
Check in printers and faxes option it is default printer if not mark it and let me know ;)
Posted on Aug 14, 2008
SOURCE:
I have a Pixma MG6150 Multifunction device. PC is sadly running Vista SP2. Trying to set it up wirelessly. Software installed perfectly on a Windows 7 pc but on this laptop it returns an error message...
Try this,
1) Go to Start/Settings/Printers and Faxes
2) Right click the "Pixma MG6150 Printer" and choose property
3) Go to the Ports page (From the top menu), and assigned to port FILE: it should be assigned to a Canon Pixma MG6150 Network port
4) Click button, and select "Canon Pixma MG6150" type, and then new port
5) The "Canon Pixma MG6150" printer will be associated with this new port, automatically
6) Click OK
Hope it can help & good luck.
Oct 18, 2010 | Computers & Internet
Can't install Canon pixma IP1600 driver on Vista
Try downloading the driver module from this site:
http://software.canon-europe.com/products/0010230.asp
Click on the link and choose your operating system as Vista and a language. Download the "Canon Inkjet Printer Driver Add-On Module". It supports 32bit and 64bit systems.
This should fix your problem.
Hope this helps,
-LL
Mar 16, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I keep getting this message jammed paper.there is no jammed paper.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-18
May 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error downloading installation sofware
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jan 09, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP500
This is the start of the fun with vista. I gives the error message "known compatibility issues" with any none MS software. It does give you the option to install anyway. Do this before plugging in the printer or vista will install it's own driver and it wont work.
the software will tell you when it is safe to plug in the printer.
you can get the vista driver @:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Jan 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP5300 InkJet Photo Printer Logo
60 people viewed this question
Clive
Clive
old marine
old marine
Ekse
