Question about Krups Small Appliances Espresso Machine
Krups XP9000 fault message that ground coffee door flap is open. but it is closed
  • lawriek Aug 14, 2008
    cannot find any feed back switch on the door without having to dismantle the unit and then voiding the warranty
  • 13,433 Answers
Since your unit is still covered by the warranty its best to send it to them, as if the switch is broken, yes it will void your warranty if you start pokeing inside and replaceing it yourself. Best solution is to take it to warranty and get it fixed.
Posted on Aug 14, 2008
  • Krups Master
  • 19,396 Answers
Try unplugging machine from power to reset it
  • Ginko
    Ginko Aug 14, 2008
    Also provide more details on the fault, what is the message? Does door close properly.
    Check the door latch, move it with your finger, it must have a small sensor, if it does lock up you can get a fault message.
  • Ginko
    Ginko Aug 14, 2008
    If it is still under warranty, see if you clear the problem in a simple way opening and closing the door, otherwise is better to use your warranty and get a repair or replacement.
Krups XP9000 The main fuse blows when using frothling nozzle. Sometimes even just when turning on the machine.
blowing a main fuse is an indication of a short or insulation failure
have an accredited electrician test the unit to find the fault
Apr 17, 2017 | Krups Coffee Makers & Espresso Machines
It always shows fill up beans but the beans container is full.. how to fix this problem for a Krups Xp9000
somewhere I read that there is a window /sensor that needs cleaned really good so it sees the beans
Jul 19, 2015 | Krups Coffee Makers & Espresso Machines
How do I replace wire in the Miele brew unit? Can't get the metal piece back in
That looks very similar but not quite the same shapes as Krups have on their XP9000 model. In case you don't know what it's for it wipes without touching across the tamping piston grille to clear any old grounds off that may have stuck on. If you understand the purpose it may help to figure out the where and how. Machine will make a few coffees without it if you need a caffeine fix. On the Krups it would clip around that winged bit of plastic by your thumbnail in the photo. Looks tro me like the brew units are made in the same place with subtle differences for brand & model.
Mar 26, 2015 | Miele Coffee Makers & Espresso Machines
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
Krupps XP9000 won't accept date so therefore won't switch on
Are you attempting to put the date in in the wrong format. USA = month and then day, normal folks day and then month. Check language setting.
Mar 28, 2013 | Krups XP Coffee Makers & Espresso Machines
When machine is turned on from the off position it does not go into rinse mode message comes up to hot please wait and yet the machine has been turned off for at least 20hrs
the power on sequence for the XP9000 is
1) Internal diagnostic
2) if no cold water, display notice and wait for water level in cold water tank
2) if water heating block is not hot, display notice and wait for block temperature
3) display "Rinse Press Hot Water" notice and wait for button press
4) rinse
5) display "Select Beverage" and wait for button press, ground coffee flap, or other input switch state change.etc...
in short... its doing what its supposed to.
Please consider reading the manual supplied wih your XP9000 or downloading the manual if you don't have it.
Nov 10, 2011 | Krups Super Automatic XP 9000 Espresso...
Krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
May 14, 2010 | Krups Super Automatic XP 9000 Espresso...
Not sure how to take it off cleaning mode. The cleaning button continues to flash?
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u will need adobe to open it
Jan 20, 2009 | Krups Super Automatic XP 9000 Espresso...
Krups Small Appliances Espresso Machine Logo
243 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
