Question about Lexmark Office Equipment & Supplies
I own an all in one printer scanner copier it is the lexmark 2480the printer and copier work but it will not scan i have gone through the instructions but it still dosent work could you help me thank you george stanbridge
  • 1 more comment
  • sooze1 Aug 14, 2008
    i have found out my scanner is not compatible with my computer thank you for your help george
  • pranit visiyait May 11, 2010
    Are you getting any error mesage while scanning it from the printer to your computer.
    regrads,
    Prani
  • IT aid
    IT aid May 11, 2010
    have you install all drivers and applications for scaner ??
  • 3 Answers
SOURCE: Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
I had the same problem. Fixed it by reinstalling the drivers for the motherboard (USB drivers in particular). Hope this helps.
Bill Scott
Dixmont, ME
Posted on Feb 23, 2008
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
stabelabel
  • 51 Answers
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Posted on Mar 16, 2009
SOURCE: hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Posted on Apr 08, 2009
SOURCE: I need a user manual mailed to me for the Lexmark 2600 scanner.
ineed a users manual for lexmark 2500
Posted on Jun 03, 2009
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Lexmark scanner will not scan to computer
Have you tried scanning using our Lexmark Printer Home software? To access the Lexmark Printer Home software, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If it doesn't work, please contact our technical support team so they can do some diagnostics.
Jan 04, 2013 | Lexmark OfficeEdge Pro4000c -...
Scanner won't work
Try scanning using our Lexmark Printer Home. To do that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Oct 17, 2012 | Lexmark Prospect Pro205 Wireless...
Bulb out
Are you saying that if you try to make a copy or scan, when opening the scanner bed cover, the bulb is not lit? If this is the case, then the scanner light "bulb" has gone defective now. Lexmark does not have a replacement for that part, you can try to have it repaired from 3rd party shops, otherwise, it's time to replace your printer.
Please try to contact Lexmark technical support center for other options.
Dec 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
My scanner wont work on my lexmark x204n . the printer works .
Please download the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
Feb 18, 2011 | Lexmark X204n 4-in-1 Laser Printer
I have a lexmark x3350 and the scanner wont scan
Alot of the X3350 all in ones have there scanners go bad if you still have a warranty for this printer then call Lexmark if not then you can go out and buy one for like $85.
Mar 26, 2009 | Lexmark X3350 All-In-One InkJet Printer
Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark x6170 will not scan
Try resetting you machines by turning off and unplug, reverse steps and try again. If no go, repost and we will try again. Cheers lilacgerry xxx
Jan 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
