Question about Cobra 29 LTD CB Radio
I have installed a supermod on my radio clipped d11 and added varible pwr to the delta tune knob it worked fine for a couple of days the varible was touchy now it will key up but will not modulate. i looked and the only thing i saw out of ordinary was the trace on the solder side were i put the resistor for the super mod has raised a bit. any advice?
  • 3,018 Answers
  • Why would you cut d11 when you can adjust VR4 and have it sound so much better? When you cut d11 you put that modulation into overdrive. Put that diode back and adjust VR4 for 100% modulation. That is step one.
  • I assume you added variable power from J36. The problem with adding variable power and not switching the pot is that the wires not only have major loss, running to the pot. And two the stock potentiometer tend to burn up if not replaced with a potentiometer that adjust power by itself. Undo this so called "super mod."
  • Start with a 1969 final for better handling of power.
  • Adjust VR4 for 100% modulation.
  • You can pull the ferrite out of the pot next to the final transistor or you can remove j36 and add a 330uf capacitor (black stripe, negative) to the rear and bias the soldier side with a 33uf resistor. Soldier the resistor to the same soldier points of the Capacitor.
  • Adjust L14,L13 and L12 for power.
Regards, Tony
Posted on May 18, 2011
How to use and operate a uniden PC76XL CB radio with description and explanation of knobs and controls
wow this ones an oldie !! I had to go out back and look at my ole 88 transtar dumper !! !! to get enough to answer this one ~~~ well starting from right to left , Volume = well that ones self explaining ~~ next ones squelch ~~ this one adjusts the noise canceling ~ the next knob is mic gain = this one might be a bit tricky ~~~ if your runnin a pwr mic already lots of folks modiflyed this knob to adjust the depth of echo !!! with echo installed but if no pwr mic this one can adjust your modulation strength!! the next knob is delta tune !! this knob lets you use sideband , although the laws have changed now!! since this thing was made !!! id keep that one in the middle so not to draw any unwanted attention from officials ~~ the next one is rf gain !!! this one lets you get a sort of private channel between your buddy and you in the truck in front of you , this one id keep right full !!! and the last one is of course channel !! this one lets you set what channel you want to operate on !! now all you need is a good antenna (don't forget to ground it too truck frame !!!) and of course 12 volt power !! use a rfi filter if you don't have a diesel under the hood ~~~ or your gonna hear lots of noise !! and your ready to go !!!
Nov 14, 2016 | Uniden Radio Communications
I have a cobra 29 Ltd chrome what is the dynamite and the rfgain and the delta tune and the talk back used for. What do you set it on
The mic gain is your output audio volume or modulation. RF Gain is you reception sensitivity. Delta tune is a gimmick it is supposed to slide the frequency a few kHz up or down for you reception of a radio that might have drifted off channel. Talkback is a tool to give you an idea of what you sound like ie quality of mic or volume or adjusting echo if you have added such a board to your radio. As far as adjustments RF gain is preferance. Mic all the way up on stock radio. Delta tune 12 o'clock. Talkback user preference. Take care......hope this was of help
Jul 25, 2014 | Radio Communications
Tuner knob no longer moves needle to tune in stations on radio
Since most radio's have digital displays these days, to have a pointer move along a dial implies it's either old or a retro model. In any case all that will have happened is that the chord or something in the drive that moves the pointer will have either snapped off or broken. It shouldn't be too hard to repair, though it can be a bit tricky to set it up right.
Dec 24, 2013 | Audio Players & Recorders
What type of diode was in d11 on the cobra 29 lts.. it was removed b4 i got the radio and id like to replace it
If it is the original 29 LTD, D11 is a IS2075K Diode. Attached is a section of the schematic showing the diode. Check the components connected to it to verify if they match those on the schematic section below. If they do, you should be fine installing the listed Diode. If they don't you may not have the model of Cobra 29 listed below.
Nov 24, 2011 | Cobra 29 LTD CB Radio
I cannot find the ARI-Z button to my car delta car radio. the instruction is press the am button simultaneuosly with the ARI-Button. where is the ARI-Z button in the delta radio? tnxs
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
Other Preferences & Configurable Options The following is the procedure on how to access some other preferences that you may set in the Audi Delta CC radio.
  • GALA and Turn-on Volume Settings
    1. Turn off radio.
    2. While pressing and holding the TP button, turn on radio. "GALA" will be shown in the display.
    3. To select the speed at which GALA activates, press the tuning up (up-arrow) or tuning down (down-arrow) buttons to the left of the volume control knob. The display shows the following:
      __' Highway speed
      _'_ City speed
      '__ Slow speed
    4. To save the setting, press both the tuning up and tuning down buttons simultaneously. "GALA" disappears.
    5. Press the TP button briefly, "VOL" appears in the display.
    6. To increase or decrease the turn-on volume, press the tuning up or tuning down buttons.
    7. To save the setting, press both the tuning up and tuning down buttons simultaneously. "VOL" disappears.
    To activate GALA, push the Treble control knob to let it spring out. Then, pull it out one more detent, and then turn the knob to the right. To deactivate GALA, do the same except turn the knob to the left. Push the knob back in when you're done.
Oct 05, 2011 | 2001 Audi A4
How to increase the power out put of my 148 gtl-dx cobra to up to 5watts ?
clip diode D11..Turn coil ferrites near finals it will numbered like say: L10,L20,L14 or something etc. It should already factory go like 3 watts to 10 watts on a real out meter. The radio meter is a simulated but not accurate meter read. But crank ferrite coils until meter reaches 5 watts on radio meter..and lock it down there OK.
Apr 18, 2011 | Cobra 29 LTD CB Radio
What its the proper way to set the knobs on this cb radio
volume is to your choice I have mine 3/4 open to get over the noise in my truck.My sq is all the way left,RF gain is all the way right. Mic gain is about half . I don't use the swr knob because I have it hooked up to an external meter . Delta tune is set to the point of the click on the knob . Thats how I have mine set and it works fine for me.
Dec 15, 2010 | Cobra 29 LTD CB Radio
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
I also have another cobra 29 ltd classic and it works fine but i cant talk or hear what other factory cb's can hear, it is supposed to be tuned and peaked and i have a wilson 2,000 antenna, and i cant talk...
nearly all problems are caused by poorly tuned or untuned antennas. a good antenna system with a cheap stock radio will out perform a great tuned radio with a bad antenna system any day of the week. if you dont believe me, check the firestik antenna website's tech notes. or wilson's tech notes.
Sep 23, 2009 | Cobra 29 LTD CB Radio
Cobra 29 delta tune
For normal operation, set this control to the center position.
This feature has several uses and can help receiver operation.
If a received signal is slightly off frequency, the Delta-Tune control can be used to òfine-tuneó your receiver. Fine tuning is accomplished by listening for a more readable signal at the speaker or by noting the Smeter reading when the Delta-Tune control is operated. Another use of this control is eliminating adjacent interference (bleed over from other channels). If an exceptionally high level signal from an adjacent channel is creating interference on the channel being used, the Delta-Tune can be used to minimize or eliminate the interference. Rotate the control until you obtain minimum adjacent channel interference. NOTE: Delta-Tune is operable only in the receive mode.
It doesn't actually help receive any better, just can help kinda like a clairifier.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 19, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
481 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
