Error on my cam,,, got etouch d33 unit,... when i start open my cam,, i got an error that says ... Camer Module is not ready,,,, What is the meaning and how do i can fix this?.. please help
  • 496 Answers
Make sure that you have properly install the camera driver properly and that the camera is connected with your computer properly and is turned on.
Posted on May 17, 2011
P1336 trouble code ho to solve problem
P1336 Ford P1336 Ford - Crankshaft Position Or Camshaft Position Sensor Input Signal Error Share
0 ' Add Comment Possible causes
- Faulty Crankshaft Position Sensor
- Faulty Camshaft Position Sensor
- Crankshaft Position Sensor harness is open or shorted
- Crankshaft Position Sensor circuit poor electrical connection
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
What does this mean? When is the code detected?
The Engine Control Module (ECM) has detected a synchronization or signal error from the cam or crank sensors
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- Engine Stall
- Engine difficult to start
P1336 Ford Description
The input signal to the powertrain control module (PCM) from the crankshaft position (CKP) sensor or the camshaft position (CMP) sensor is erratic.
Read more: http://www.engine-codes.com/p1336_ford.html#ixzz3qT9Hiztc
Nov 03, 2015 | 2005 Ford Freestyle
Micromax x510 - camera module not ready
I purchased Micromax Van Goh last month. Within few days of usage it is giving following error when I try to use camera or camcorder:Error ''Camera Module Not Ready''. Any solutions?
Jul 13, 2011 | Nokia N95 Cellular Phone
Change the camera to the primary camera at the back, if i open the camera it says camera module not ready. Nokia E*#
it means dat the error is with Hardware not Software.
so u must repair ur 4n 4rm specialist
May 21, 2011 | Cell Phones
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
I need to know what the code 18 and 41 means for 93 Buick Park Avenue Ultra with a 3.8 litre supercharged eng
When fixing codes start with first code first / it dos not always mean that the sensor is the fault ,it could be in the harness / the plug or the ground. and reference signal should be tested , but in this case you most likely could get away with replacing the cam sensor, that would be the Lest expensive and easiest to start with,to git to it you will have to remove the alternator hope this is help full, the other code suggest that it could be the crank sensor , that and the plug for it does fail quite often but first things first feel free to ask if you should have any further questions , Thank you ,
Mar 31, 2010 | 1993 Buick Park Avenue
China nokia e71 camera problem
hi guyz plzz help me wid china e71 tht whn i m opening my camerait says tht camera module not ready
vishal
Aurangabad
Dec 24, 2009 | Cell Phones
VM L450
These units are known for having bad "operation units", which consists of the switch that selects camera or vcr and the zoom unit. If you try quickly switching back and forth between cam and vcr and at least get a flash on the display, that is problem. Also, you can try slowly moving the switch (very slowly) between cam and vcr and awtaching to see if the power LED comes on at all. I have replaced many of the operation units on this unit.
Oct 22, 2008 | Quasar VM-L450 Camcorder
My jvc gr d33 dont have a back light that is hard to see on my screen .is their any adjutsment for that or i need to bring my cam to fix a back light?
Please locate RESET push button in camera (its tinny button pushed by ballpen) and perform reset.
2nd possibility is broken ribbon wire connecting lcd and main board of camera. in this case you need qualified technician or JVC service center.
Sep 08, 2008 | JVC GR-D33 MiniDV Digital Camcorder
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Error Codes 9-343
That means , second BTR is not in contact with transfer belt. Open front door and pull out paper transport and check that is everything OK with black roll and her assembly.Check sensors for dirt,and gears for damage.If You have used one ,replace it.
Nov 10, 2007 | Xerox DocuColor 12 Printer
Computers & Internet Logo
David Payne
David Payne
