Question about Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg
We are getting the message Asic error? Could you please tell me what this means.
Error code e00747-221f for machine canon irc3580
Sorry to say this error is a main board fault and that will need to be replaced. Expensive!! the following is from the manual:
E747 Main controller PCB error (Image processing ASIC or memory control/communication control ASIC)
Dec 18, 2013 | Canon iRC3580
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
What does E7 Error code mean for SHarp AL-800 copier?
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Sep 19, 2010 | Sharp AL 800 Copier
Error code 6500
Error 6500 is a hardware error.In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Please rate your response.
Thanks, SF
Feb 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error message 0500h
Your fuser is not warming up. You will need a technician to look at it.
Mar 16, 2009 | Konica Minolta magicolor 5430 DL Laser...
Phone restricted
Usually you should use code number 7. If it does not work, try code 1. Different codes work on different phones. Remember that you only have 5 tries, after that you have to go to a repair shop.
This code is calculated for:
Model: Nokia DCT4 (ASIC 2)
IMEI: 357954000612553
Network: 23430 (T-mobile UK)
#pw+224605064550241+1#
#pw+810291350146537+2#
#pw+180734320101076+3#
#pw+821921665233661+4#
#pw+079613612000350+5#
#pw+826731564741375+6#
#pw+832771773351210+7#
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
Jan 24, 2008 | Nokia 6030 Cellular Phone
Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg Logo
77 people viewed this question
Top Ge Medical Systems Medical Experts
Steven Clarke
Steven Clarke
Fred Murdock
Fred Murdock
ka4iup
ka4iup
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
