Question about Acer Aspire One D255 Netbook
Acer aspire one d255e card reader wont read sd cards
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
i changed my hard drive .. and my computer has an SD slot .. but it wont read my card when i insert it .. odes it have to do with the new hard drive .. what can i do ..
Posted on Sep 10, 2008
Felinna
  • 42 Answers
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Posted on Feb 23, 2009
  • 514 Answers
SOURCE: Acer Aspire card reader not acknowledging SD card
go to Wal-Mart or K-Mart and such, you can get a SD reader/ writer (such as Targus, about $9 USD, what I use) and put your SD card into it, then plug into USB (USB 2.0 is current standard, but will work with USB 1.1, just slower). PC will ask if you want to play/record from/to the removable drive, select "take no action" then go to the "my computer" icon (or what ever you have named it) double click the drive letter for the flash/SD card (E,F,G etc.). open the file folder that you want to copy from <usually something like "100MEDIA" or such> (I STRONGLY recommend that you "COPY FILE(S)" and NOT "move file(s)" as that if something crashes you still HAVE the orig. files) select to copy to the correct drive letter/ file name(s) and PLEASE remember to "remove hardware safely" or you could KILL the files and/or the drive(s) that you were using. (did that TWICE before I realized what I was doing wrong). good luck!
Posted on Apr 15, 2009
  • 192 Answers
SOURCE: Acer Aspire 4520 doesn't read SDHC cards
No, there is a simple fix. However, it involves flashing the BIOS on the laptop.
Don't worry, there's not much chance of it going wrong as long as you follow their steps of flashing the BIOS (Incidentally, it's stored on most laptop hard drives).
The reader will accept a larger chip if the updated BIOS on the laptop manufacturer's website is written to do it. Contact the manufacturer via email first just to make sure.
Posted on Jul 27, 2009
SOURCE: How to insert SD memory card into card rader in laptop computer
It appears to be blocked, what you have to do is push it in (blocked door) then it springs the cover off .
Posted on Apr 18, 2010
Acer aspire 5552-7819 laptop does not
Not sure what you mean, but if your sd card is not being recognized by your laptop it could mean you need to reinstall your drivers.
Before doing this try using a different sd card incase there is a problem with the one you are using.
Jul 17, 2014 | Acer Aspire Computers & Internet
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
I have a acer Aspire Ei-571 laptop.I insert a sd card to it's card reader.sd card is a new one there arn't any files in that card. so when I insert the card to the reader I can't open it.so what do I need...
u more than likely need to format it first so your computer can read it.
see if it appears in windows explorer, if not copy a file then right click and send to the SD card and the option to format should appear, format it and this should fix your problem.
Oct 14, 2013 | Acer Aspire E1-571-6650 Laptop
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
My acer can read an sd card,How can I get it to
While the spec sheet does not say SDHC specifically I am surprised it does not read and write it since it is an up to date unit but if it wont you can get an inexpensive USB 2.0 reader and it will work. I would check and make sure that the SDHC card is formatted properly if it is go with the adaptor. Good Luck
Jul 27, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer aspire integral SD card reader
install the proper dirver by opendriver.com and enjoy. raheelahmadkasuri@gmail.com
Jul 12, 2009 | Acer Computers & Internet
I can not get my acer aspire m5641 to read my media SD card
the drivers for the sd card reader are probably not installed if its a build in reader, if its a usb reader it shouldn't need any drivers.
http://support.acer-euro.com/drivers/downloads.html
Jun 11, 2009 | Acer Aspire RC500 PC Desktop
Sd card
i had this problem so i put my SD card in the reader and restarted my laptop as soon as it logged on it said installing new device now the card reader works everytime
Jan 19, 2009 | Acer Aspire 6920 Notebook PC
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
Jul 15, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One D255 Netbook Logo
963 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
