The fan outside always runs even when it's shut off inside
    Guru:
  • 683 Answers
There is only a couple of things that can cause this. If the fan and compressor are on one contactor they should both be running and you probaly have a contactor that is stuck. If the fan is on a fan relay and the compressor is on a contactor you may have a stuck relay. On the panel is a wiring diagram, look for something called odf, this stands for outdoor fan. When you locate it try tapping on it with the back of a screw driver and see if fan shuts off.
Posted on May 17, 2011
Sometimes the fan inside comes on but outside unit isn't running
Its likely a computer generated time delay so the refrigerant can equalize pressure. Its a safety working properly.if people are fighting over the temp, and it shuts off and someone turns it down to soon, the result you described is normal, even essential.
Jul 15, 2012 | Coleman York Evcon Furnace Control Circuit...
Does your furnace have an adjustable fan limit switch it has to be adjusted. If it has a timer check if it can be adjusted.
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
Outdoor fan will stop running and compressor overheats and shuts off. it wont come back on til u reset it at the thermostat. the outdoor unit has a new compressor and fan motor.
I realize the outdoor unit has a new compressor and fan motor - therefore - both those components should be ok - however - the fan motor 'should not' be going off - and the fact that it is going off is what is causing your compressor to overheat and shut off.
The reason the fan motor is going off is - it is bad (breaking down electrically) and is going off on the internal overload. If this is the case (a) the motor needs to be replaced or (b) it's possible that the fan capacitor needs replacing; but fan capacitors generally do not cause much problem, and when they do go bad they usually develop an obvious (to the eyes) bulge. If the capacitor has a bulge in it - I would surely change it out -and probably would (as a shot in the dark) anyway - since they are relatively cheap ($10-$15).
In your complaint you say that "the outdoor fan will stop running and compressor overheats and shuts off." If it happens 'exactly' that way then I'm betting your problem will be that the fan motor is defective as mentioned above, with an outside chance of the capacitor being defective, in which case if it isn't the capacitor - you will need a new fan motor. Note: outside fan motors are notorious for being fickle and it would not surprise me in the least to find a fairly new outside motor that is defective. I would check and see if you had any warranty on it.
All that being said - it is also possible that your outside unit has a 'high pressure cut-out switch,' although most units don't have them anymore, these days. However, if you have such a switch - it is possible (very likely) that it is shutting off the AC. Note: a high pressure cut-out switch will 'shut the entire outside unit off,' not just the fan motor. If that is what is happening then there's a good chance you have such a switch.
If it is happening that way, (the entire outside unit stops) then I would try 'washing the outside coil' really, really good and see if it will run ok afterwards.
Note: outside coils are sometimes difficult to get clean - sometimes requiring you to disassemble to some degree in order to make sure you get them clean.
Always, Always turn all power (including inside thermostat) OFF when washing the outside coil.
Jun 07, 2011 | Heating & Cooling
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Outside fan runs constantly Aux Heat only 50%
Let's start out by your statement that the fan would not run, then you changed the contactor, not it won't stop running.
I believe, based on your info, here's what you need to do. Kill power to the unit. The 2 wires bringing power to the outdoor unit should be on the top 2 terminals. The 2 fan wires should be on the bottom 2 terminals. This is providing that the contactor is mounted Vertical. The could be an outside chance that the unit has a short in it and you are getting voltage feedback somewhere.
Take another look.
Dec 30, 2009 | GE Zoneline AZ55H09D Air Conditioner
Ac fan won't turn off. Even when the engine is off and keys are removed.
this problem is caused by a shorted blower motor speed control modual/resistor, it is located next to the blower motor in the air ducting replace it.
Dec 27, 2009 | 2001 GMC Safari
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
