Question about Weber Q Grill
Q-300 plastic tank nut broke, where can I find serial number for replacement
    Brigadier General:
  • 4,736 Answers
You will need to replace the entire hose/regulator assembly. As the plastic tank connector is not sold as a separate item/part. You can buy a new hose/regulator assembly for about $30.00 at any home center or hardware store that sells gas grills and accessories. Take you old hose/regulator assembly with you for comparison purposes.
Hope this helped you to speed up the replacement part and get you back to grilling.
Posted on May 17, 2011
What is the best way to refill a sealed radiator unit for 1998 ford f150
When engine cold, Unscrew the radiator cap on the expansion bottle and top up the coolant level to the minimum level marker, then replace the radiator cap.
Nov 22, 2015 | 1998 Ford Contour
Lexus 1996 es 300 evap canister p0441
if you look at diagram below on top of tank it shows a line going to evap that would mean its located behind or next to fuel tank its a some what rounded canister about 8in long and 5 in wide .black plastic.
Sep 30, 2014 | 1996 Lexus ES 300
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
Husqvarna 240 cover tightener broke, how to remove cover
As the nut is already damged and needs replacing you may as well just grab the nut with a pair of vice grips to remove it, it should not be that tight.
Nov 23, 2012 | Husqvarna Garden
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
I have a 2001 Chevrolet Suburban 2500 4x4 6.0 liter engine. This vehicle has engine oil cooler located the radiator tank drivers side. I have developed a coolant leak located where the upper threaded...
The procedure you are thinking about doing is the correct procedure but you need to know that there is a rubber seal behind the large nut. Best to remove the line, remove the large nut and replace the rubber seal. Overtorquing the nut will crack the plastic radiator tank. Double check BOTH fluid levels and conditions when finished.
Sep 25, 2010 | 2001 Chevrolet Suburban
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
I am installing a new kitchen faucet and have two problems. Number one the plastic flange njuts that hold the old faucet to the sink won't come off. I tried to loosen them with WD-40 and white vinegar. No...
First of all, you need a faucet wrench. It's about 12 inches long, has a t-handle on one end and jaws on the other -- this will grip the plastic nuts to remove them.
I'm not sure what is meant by breaking the seal. If the soldered fitting broke loose, the best approach is to cut the copper pipe off past the damage and solder a new fitting on it necessary for the new hose to screw onto it.
There are a lot of ways to solve this problem -- if you can't manage the soldering, we can discuss other options.
Apr 20, 2009 | Plumbing
Weber Q Grill Logo
106 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
