Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have a Kenmore refrigerator that perodically will just let a puddle of water out on the floor underneath it. The drain pan underneath is dry so I know that it's not overflowing. I had a service person look at it who couldn't find anything wrong. I'm thinking it's probably in the defrost cycle but what is causing the water to totally miss the drain pan underneath?
    Guru:
  • 683 Answers
There should be a hose underneath the fridge that needs to be put back into pan.
Posted on May 17, 2011
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Mdz2766ge maytag fridge; water puddles on floor when defrost kicks in
Check the drain tube from the defrost coil near the evaporator to the drain pan.
Jan 29, 2014 | Maytag Refrigerators
Occasionally my freezer will defrost and will make a big puddle of water on the floor.
the drain from the freezer is probably plugged as well theres a drain pan under the fridge , look underneat an u will probably find the problem , make sure the drain pan underneath is not full of stuff
Oct 16, 2010 | Miele KFN8762SDED Bottom Freezer...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
My model 106.9730680 refrigerator runs good and gets cold every once in a while a small puddle of water collects on floor in front of unit the evaporator tray never has any water in it , I've checked ice...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer2_bing.gif..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 29, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
We have a 2-year old Kenmore side-by-side with a "Por" Ultimate filtration system. We cannot figure out how to empty the plastic pan underneath the refrigerator that has the water drip in it. Also, we...
you shouldn't have to touch that pan the water should evaporate by itself,are you sure you don't have a blocked drain in the freezer?is there ice on the freezer floor?if so melt out the ice in the back at the bottom of the freezer wall and then pour hot water down the drain to see if it's clear if not you have to find something you can stick into the hole to clean it out,i use a steamer to unblock the drain you can get one for 40 bucks it's a shark super steamer,if that's not the problem you could have a cracked water line,you'll have to take off the back panel on the bottom,and check the lines,have someone draw a glass of water while you check out the water line or it could be from the ice maker line if you have an ice maker
Nov 24, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No cooling no freezing puddle on floor
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Apr 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
200 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
