Question about Apple MacBook Pro Notebook
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old) I used pre-Mac. The Dell projector was bought because it supports XGA projection, and I need sharp images and great color in my presentation. Problem: When I hook up the Air to it, the color is terrible on the projector. It's quite dark, not at all sharp. I've got the miniVGA hooked up to the VGA cord to the overhead, it's mirrored, and the prefs show it's projecting at 1280x(800? Don't remember), 60 hz. I've changed mirror to not mirror; changed hz, changed resolution, and always the same. I've tried hooking up to a nice monitor from the Mac via VGA and it looks great, so I know the connector works as does the cord. The Dell projector also has settings, which I've tried (different resolutions, contrast, brightness), and nothing has worked. I've also had all shut down, hooked up, and then turned on, and no significant difference. Help! This hardware was supposed to work well together, and Apple was no help on the phone (they blame the projector).
  • jaluban Aug 11, 2011
    VCitron, the only thing I didn't try was to make sure the projector is not set to Eco mode, which compromises color and brightness. Check it out and let me know.
    I'm about to buy this one instead and pray it works: http://www.amazon.com/Epson-PowerLite-17...
    Hey, check to see if the projector/bulb is set to Eco mode. That's the only thing I didn't try. Let me know. Eco mode often makes the color and brightness compromised.
    I'm now looking at this one and praying it works: http://www.amazon.com/Epson-PowerLite-17...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
Posted on May 17, 2011
  • jaluban May 20, 2011
    Thanks for that. The projector is working fine w/PCs and other Macs, it seems, so I know it has to do with the Macbook Air.
  • vcitron Aug 11, 2011
    We have exactly the same problem. When we go into the mac display settings and calibrate to fix the color, the dell auto adjusts and turns something half-way OK back into junk. This has not happened with other projectors so there must be some interesting communication mismatch.
Is the Macbook Air enough if I onlz want to use for private leisure?
It's a good product but has it's limitation in terms of no CD/DVD drive, lack of USB ports, quite a small hard drive (80 GB as opposed to 500GB for a low end Macbook Pro), less RAM and smaller screen (11.3 inch as opposed to 13 inch for a Macbook Pro). For another 200 dollars you could buy a macbook pro which has higher specs.
Jan 02, 2012 | Apple MacBook Air
Hello, please tell me how to flip the image upside down. I ceiling mount my M410HD and I can not turn the image 180 degrees. Thank you, Mircea
Go into projectors menu, and you'll find sub menu "display" and it will give you options front, rear, etc and choice front, ceiling
Mar 15, 2011 | Dell M410HD Projector Projector
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
Macbook screen crashes when connected to projector
this is probably a projector setting
try checking the setting of both systems
May 09, 2010 | Apple MacBook Mac Notebook
Can i hook up a macbook to this projector?
sure can!
There are a few options. Check out the apple website for a list of adapters.
Your best bet, depending on what macbook you have, would be a mini-DVI (plugs in to your macbook) to a DVI (plugs into the projector computer input)
The adapters are quite cheap at around $15 adn this will make the projector work just like an extra monitor connected to your macbook
Good luck!!
Feb 20, 2010 | Hitachi CP-X1200 Multimedia Projector
I have a new mac pro and I am trying to use it with a Dell LCD projector. It shows the homepage without any text and won't show anything else.
What do you mean by "shows the home page"? What home page?
Normally you will see your mac's desktop (or, on some models) you will see your desktop background without any icons. If that happens the projector is acting as an extended screen.
If you want to project exactly what you see on the laptop's make sure that mirroring is switched on in the monitors panel of system preferences.
Jan 30, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
Mac driver need for dell projector
You shouldn't need a driver as long as the Mac video system resolution can be matched by the Dell projector. Considering you are using a Mac Pro I don't think this will be an issue. Have you tried it and it didn't work?
Mar 28, 2008 | Apple MacBook Pro Notebook
I need a part for my DEll 2300 MP Projector!
I have a 2300mp. Everything works great, except the fan stopped turning. The lamp has only a few hundred hours, I bought it new just a few months ago. Willing to sell for parts. My email is heyjoepala@yahoo.com
Jan 10, 2008 | Dell 2300MP Multimedia Projector
Apple MacBook Pro Notebook Logo
332 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
