Question about Water Heaters
Need instructions on how to drain and flush. - Water Heaters
You posted under water heaters.
Always let a water heater cool off before draining.
Hot water can cause serious burns. Immediately put burned area into cool water.
There are different types of water heaters, and each might drain and flush differently.
Open following link for typical gas and electric tank-type:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
To drain and flush tankless, it can be called de-liming tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Be sure to read tankless manual for instructions and advisories, and required maintenance.
If you have boiler, or indirect water heater, solar water heater, or RV heater, the instructions above may not apply. be very careful with a boiler due to extreme high temperatures.
Add a comment and give more information about heater, for possible help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 17, 2011
Brass drain valve not working.
they get stopped up leave pressure on tank don't shut cutoff off hook up hose and run to outside then open drain valve with pressure on it for a min. it should flush.
May 03, 2016 | Water Water Heaters
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
How to clean a water heater
turn off breaker to heater if it is electric, turn off gas if not. turn off water supply to heater. Hook up hose to bottom drain (if one is not all ready piped to outdoors). Open water drain valve at bottom then open any hot water side of the faucet. Tank should drain down, taking some of the buildup with it. Once drained, close faucet that was opened, turn water supply back on and flush out remaining deposits. It may be neccesary to replace the anode rod from the top of the heater if you have excessive build up.
Feb 08, 2013 | Water Heaters
I need to flush my Atwood L/P Gas water heater MPD 93756 I'm unable to locate where you add the vinegar. Can you advise!
Remove hot pipe connection, and flush out through drain valve.
Or remove TP valve and flush out through drain valve.
Connect small circulating pump to 5 gallon bucket with 2 gallons white vinegar like they do with tankless water heater, as shown following Bosch manual. And let run for 45 minutes.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
White vinegar is safe for humans.
If odor is the problem, use H2O2 hydrogen peroxide, and not bleach. Hydrogen peroxide is safe for humans and easy to flush out of water heater and pipes. While it can take weeks to get rid of bleach, which is caustic and toxic.
Oct 26, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
Our hot water will last for about 5- 10 minutes then turn luke warm. I have replaced both elements but problem remains . Do you hink it is the thermostat ? thanks chazz
If you have not done so already then turn thermostats up to 140 degrees. You may also try to drain and flush tank to clean out any mineral deposits that could be hurting your effiency. To do this shut off electrical power to heater then connect garden hose to drain valve on the bottom of tank. Run hose to floor drain or other safe area and open drain valve. If it drains good with the water on then let it flush for a couple of mins. then shut incoming water supply off. Let tank drain as far as it will. You may need to open a faucet on the hot side of nearby fixture to break vacumn.
Drain it completly then close drain valve and hot side of faucet.Turn water supply back on and let tank refill. Do this 2-3 times to get inside of tank as clean as possible. Hope this helps you and thanks. P.S. You may need to replace thermostat also.
Mar 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I'm flushing my radiator in ford e-350 v8 with 5.4l......has strait water in it now......when i flush I'm trying to figure out where the heater return hose isto flush the core or do I even need to...
when i flush my radiator.i would first drain out all my old antifreeze.fill radiator up with water then put a bottle radiator flush. pour in radiator.then i will crank car up turn on heater wide open allowing radiator flush flush out radiaator and heater core when done i will drain out water. put in more water flush out all radiator flush out engine and radiator.then put back in antifreeze.you dont want to run water hose to heater core it will rupture it water pressure too high.
Dec 08, 2009 | Water Heaters
I think I need to drain/flush our hot water heater
hi first making sure not to burn yoursel switch of heater and drain down down water from taps this may result in causing an air lock dont worry ! at the base of the heater you have the stat and element housing first withdraw the stat then the element alowing any remaining water to drain when fully drained turn on your water supply to flush out and clean replace element and stat using plummers sealent or tape hope this helps
Nov 16, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Water Heaters Logo
146 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
