Question about Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD245PDB14 24" double oven. Stops
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
SOURCE: Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Posted on Oct 28, 2008
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
fixyourboard
  • 310 Answers
SOURCE: Displays F2 E6 on Whirlpool RBD305PDQ10 double
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
www.fixyourboard.com
Posted on Mar 05, 2010
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
When the pyrolytic function is switched on the oven starts the process then after about ten minutes the code f1 appears on the digital control panel and stops
Hello katefreeman1 - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD sensor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 22, 2013 | Electrolux EOC6690X Pyrolytic Electric...
We have a Whirlpool gas range model SF379LEKS that was purchased new in 2004. The oven heats up at first but then stops heating, even though the display says it's still on. There are no error codes. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 03, 2011 | Ovens
Whirlpool Gold model #GS395LEG oven control panel shows it is preheating, but you don't hear the click and the gas doesn't ignite. Ten minutes later, no heat!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 09, 2010 | Whirlpool RBD305PD Electric Double Oven
F2 error on Whirlpool RBD245PD Double oven
F2 is a bad temperature sensor.
The no lights function is a bad clock control.
Jan 10, 2010 | Whirlpool RBD245PD Electric Double Oven
Oven heats for 5 minutes then shuts off
The touchpad has a ribbon connector to the main control. Remove the control panel re-insert the touch pad ribbon into the main control tab. If it is not a bad connection the touchpad will have to be replaced.
Jul 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
70 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
