Question about Kenmore Refrigerators
FAN SEEMS TO BE RUNNING BUT ITS NOT FREEZING AND NO COOL AIR TO REFRIDGERATOR, I GET A BUZZING SOUND FOR A FEW SECONDS AND THEN IT GOES OFF, THEN AFTEER ABOUT A MINUTE OR SO IT DOES IT AGAIN.
    Guru:
  • 683 Answers
When you refrigerator is making a clicking sound every few seconds this can be caused by a couple of reasons.
1. The pressures are not equilized enought to start the compressor. This can be caused by the head pressure getting to high and not coming down far enought in the off cycle so that the compressor can start.
(things that you can do at home is to make sure that the condensor coils are clean. the condensor is either located on the back or on the bottom of the refrigerator. Make sure that the fan on the bottom is clean and blade clean and that the fan is operating.) When you clean everything let the refrigerator stand for 1/2 hour unplugged before you plug it in this will allow the compressor to cool down and also allow the pressures to equilize. If after doing this it does the same thing and you dont know what else to do and are not mechanically inclined, call a service man.
2. This can be caused by weak or bad start componants. When and if you change any start parts it is good practice to change all start parts. (start capacitor, run capacitor, start relay, and overload. To many times one start part will go bad and the short cycling will take a toll on the other parts. If you know how to read a volt ohm meter I have phone support and can talk you thru it. If you do not, call a service man.
3. Other reasons are in the refrigeration system and this will require a service man.
I hope this was helpful to you. Have a great day and good luck.
If this tip helps you, please give me a rating. thanks.
Posted on May 17, 2011
Just replaced the capacitor, and reconnected. Turned power on and heard a buzzing sound from the condensor, then the fan turned on. the unit only runs for a few minutes then shuts off
The buzz is the compressor failing to start.The blue or purple wire from the compressor goes to herm on the capacitor. If it's wired right and does not stare the compressor is bad.
Jun 23, 2014 | Bryant 2 Ton 17 Seer Air Conditioning...
I have a Maytag 2651HEW . Seems to be cooling and
Thant must be checked out soon as that buzzing sound is the start relay struggling to start the compressor. The longer it goes on without repair to either the sart/run capacitor, start relay and overload the higher the chance there is for complete compressor failure. The condenser and evaporator areas should be cleaned and inspect both internal freezer fan and lower condenser fan that both run without stopping. Let me look for a service manual for your model and return soon, Thanks, Sea breeze
Jan 10, 2010 | Maytag MSD2651 HE Side by Side...
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
May 03, 2009 | Heating & Cooling
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerators Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
