Picture to dark so i replaced lamp and picture still to dark
  • 8 more comments
  • Daniel Cobb May 17, 2011
    sony kdfe42a10 wega picture was dark tried all adjustmants then replaced with new xl 2400 lamp still have same problem picture too dark.plz help . i used to work in tv repair shop and im sure with right info i can fix this tv . but that was back in the 80s.thanks .danny
    actually all i did was run the antenna matv section of the business but i did pick up on a lot of the zenith and rca service but i really have no technical knowledge of espicially sony stuff . if you can direct me with any kind of adjustmants or anything i would greatly appreciate it . ps I bought this set through a friend of a friend who said the unit worked fine and when i got it home i found out that iwas duped or that they were used to watching this tv in complete darkness.and was used to it. but i have nearly 300 dollars invested now and im really feeling quite helpless now .plz help.
    ok plz send manual and codes i believe there is way to reset lamp hours counter anything u can do will help also if u can direct me to any adjustmants on boards or back of tv will help, cause as far as i went was to clean all fans and only removed bottom panel. thanks
    sorry my email is danny.cobb27@yahoo.com
    ok even though my printer not working with this computer i will just save email thanks.
  • Daniel Cobb May 19, 2011
    well i appreciate ur help the manuals helped me get to service screen but i cant see certain things like numbers for entering on remote. they are way to small. cant even see with my bifocals if u could send some just a little bit enlarged it would help. Thanks ur friend Danny.
    I bought a sony wega lcd 42 inch model kdfe42a10 and picture was really dark so I ordered new lamp xl2400 and replaced lamp but picture still way to dark even with all brightness and picture levels max ed out.I am at my wits end i sure could use some help i invested too much i believe. trying to help a so called friend who said everything worked fine. dont ever buy a tv when they already have it setting on front porch.
  • Daniel Cobb May 23, 2011
    I have sony lcd wega kdfe42a10 replced lamp took everything apart cleaned all optics and mirror but picture still to dark to watch even at nite.is there some board i need to replace or some adjustments one person sent me service manual but was to small to read numbers.plz help.
    sony lcd kdf-e42a10
    yes i have a digital multimeter and do you suggest testing the clips that the light plugs into?
  • 4,889 Answers
Please tell me whats the make and model of your tv so that I can help you with your problem. I am supposing this is a DLP or LCD rear projection tv. Just wanna know which one of them it is.
Posted on May 23, 2011
  • eagle338
    eagle338 May 23, 2011
    The problem can be due to a ballast malfunction or due to a faulty DMD board. The first thing to try would be to measure the output DC voltage from the ballast to see if its OK. Do you have a multimeter and know how to use it?
  • eagle338
    No. the thick wires from the lamp will plug into a board known as ballast. The point from where the wires come are the DC output pins. Measure the output voltage at that point with the tv(you will have to disassemble and have the board on a desk or something before hand). The service manual indicates that the output at the point should be 325-340V. Let me know how much it reads
  • 1,606 Answers
If the set has a lamp, I assume it is a rear projection TV with an LCD panel.
There are several possibilities. I presume you have already investigated the brightness setting in the TV control menu. That leaves the following:
If you have a smoker in the house, you may have tar buildup on the optics. Follow the manufacturer's instructions for cleaning the front screen. If the results are still not satisfactory, you may have to clean the internal optics. Caution: make sure the set is completely cool, and unplug it before cleaning the lenses and plates inside the set. Do not apply the lens cleaning liquid directly to the optics; there is a risk of dripping it into electrical or electronic parts. Apply it to a soft lens cleaning cloth, then use that to wipe the optical parts. If you removed a noticeable amount of tar from the front of the screen, you may also need to clean the curved mirror assembly that lines the upper back of the set, as well as the back of the projection screen.
If you have an oxidized terminal in the lamp holder, the bulb may not run at full brightness. On many sets this would generate a lamp error, but it may not be the case on yours. Remove the new lamp and inspect the terminals. Polish them if they are tarnished.
The ambient light in the room may be too bright, or the cover of the light level sensor on the set may need to be cleaned if it has one.
There could be a problem in the lamp regulation circuit besides the previously mentioned ambient light sensor. At this point you're getting into the electronics, and a service manual would be highly desirable.
Posted on May 19, 2011
    Top Expert:
  • Televison & ... Master
  • 75,452 Answers
Hello
What is the brand name and model number of your projection TV. Without it, how can i post a solution before you? Inform me these details. OK.
Posted on May 17, 2011
  • 5 more comments
  • The Knight
    The Knight May 17, 2011
    Hello Danny
    If I send you the service manual of your Sony TV, can you follow it and troubleshoot?. It is better I thinks, because you are an experienced person. If you are interseted, send your email address to me by Fixya. I've the original service manual of your set, and I'll send a copy of it to you. OK.
  • The Knight
    Hello
    The set you have purchased is a very old model. Nothing can be done by you without proper experience in servicing this type of TV. In service manual, there are self diagnosis process described, but all cannot be typed here. There are some codes to enter into its service menu and are described in the service manual. But proper care must be taken when entering ito it. You have been cheated I thinks. What can I do, as you are not aware in electronic circuit boards and circuits. A wll expeienced service personal only can do something to this set. soemtimes he also may helpless. OK
  • The Knight
    Danny .. You haven't given your email address. Without it how can I send it to you? Provide it to me please. I'll send you both the service manual and user manual of your TV.
  • The Knight
    Ok. I'll send the documents to you now itself. Expect it from 25 minutes from now. You can contact me at if you want anymore assistance. OK.
  • The Knight
    Danny .. I've send the documents I promised you a few second ago. Go to your mail, and download it. OK.
  • The Knight
    I thinks that you have got my mail. View all adjustments described in the service manual. I'm sure that it will help you.
  • The Knight
    The Knight May 23, 2011
    Hello
    What is the brand name and model number of your projection TV? Please provide these details to me by FixYa. OK.
2 Suggested Answers
  • 556 Answers
SOURCE: dark picture
IT WOULD PROBABLY HELP IT, THE PICTURE NORMALLY GROWS DARKER WHEN THE LAMP GETS WEAK
Posted on Aug 18, 2009
DLP television picture not clear (blurry) and dark.
Hello
If picture is dark in DLP TVs, its lamp should be taken care of. In some lamps, the reflecting side coating of lamp will be bubbled, preventing sufficiant light to fall on DLP chip. Replace the lamp if necessary. Check it first, taking it ouside. OK.
Apr 15, 2011 | Mitsubishi Televison & Video
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Very dark picture. Video adjustments do not help.
I would check the lamp first. Open the lamp door to see if there is cloudiness near the stem of the lamp. If so, replacing the lamp should make the brightness like when you first bought it.
Oct 11, 2009 | Sony KDF-E50A12U 50" LCD HDTV
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture
Aug 17, 2009 | Sony KDF-E55A20 55 in. LCD Television
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
