Question about Refrigerators
Compressor on my whirlpool refrigertor (model no et21pkxgwo1) tries to start then kickes off after about 20 sec then a min later it tries to start again started diong this yesterday then last night it ran alright then this morning it started doing it again
  • hogfl1 May 17, 2011
    relay is making i clicking sound when trying to start the compressor also when i took it out and shoke it it rattled think its the relay thats bad
    Top Expert:
  • Refrigerators Master
  • 74,383 Answers
Hello
Check the stabliser used with the refrigerator. Disconnect it from the stabliser and plug direct to the AC wall socket and check. If it does work properly, stabliser has some trouble. It drops the voltage to the fridge, when motor starts and takes current. Start up current will be greater than running time current. Check this. OK.
Posted on May 17, 2011
    Genius:
  • 1,196 Answers
The most possibility is that the compressor may be FUBAR. You can check this with your ohm meter. Set it on the lowest setting and then measure the resistance between each of the three pegs sticking out from the compressor in the control pod the same ones that the start relay and overload connect to. Should read something in the low ohms. If the reading between any two pegs is infinite resistance, then one of the windings in the compressor motor is burned out. You should also measure from one of the compressor pegs to ground with your ohm meter on the highest setting. If you read anything, the compressor has developed a path to ground and is bad. In this case, you will need to replace the compressor. If you are not comfortable handling electronics, it is better you get someone who can do it for you.
  • Ishola Olayemi May 17, 2011
    The function of the start relay is to momentarily energize the start
    winding in the compressor motor and then cut power to the start winding
    as soon as the motor is running. Most of the start relays on modern compressors are solid state and use a
    special material whose resistance increases with temperature. So, as
    current flows through the relay and the relay heats up, its resistance
    increases to the point that the start winding is isolated from the rest
    of the circuit.
    A common failure of these relays is that the solid state material
    "cooks" and breaks up, staying open and thus never allowing the start
    winding in the compressor motor to energize. The end result is that the
    compressor tries to start, usually you'll hear a humming noise, and
    then, after a few seconds, the compressor's overload protector takes the
    compressor offline with a loud CLICK.
    Easy way to tell if the start relay is bad is by simply removing it
    from the compressor's control pod and shaking it. If you hear any
    rattling, it's fried.
My freezer start only a few sec. After 10minutes start again
Roy,
Sounds like something is causing your compressor to kick the overload. It could be the overload itself or it could be the start relay or it could be a locked compressor. Probably best to call a service tech.
Apr 29, 2015 | Freezers
I have a whirlpool fridge/freezer which after a power cut will now only register 7 on the freezer, although still seems quite cold. How can I get it back to -18 ? Thanks
If the power loss was for 5 mins of less.... just unplug it for 20 mins and plug it back in. The compressor is probably "High side cycling" and the thermal overload is tripping on the compressor every 4 - 5 minutes for about 40 seconds. Unplugging it 20 minutes will allow the coolant system to stabilize and the compressor to re-start.
Kelly
Apr 28, 2011 | Whirlpool Refrigerators
I have a 1992 honda accord we have repalced comperssor both engine fans and added new freon with oil ....but the compressor does not kick in until 20 min later? baffled
prior to adding the freon did you have system evacuated with a vacuum pump???? If not there is air in your system causing the delay reaction for compressor to kick in
Jun 12, 2010 | 1992 Honda Accord
SIDE BY SIDE Admiral Refrigerator model # ASD2123DR'' NOT COOLING. THE FAN INSIDE AND FAN OUTSIDE BOTH WORK AND WHEN THE COMPRESURE COMES ON THE LIGHTS DEM FOR ABOUT 5 SEC THEN IT CLICKS OFF AGAIN ABOUT 1...
Good day,
That clicking off and on is the compressor trying to start, and can't.
On the side of the compressor, is a cover, that when removed, will expose the starting components.
They consist of the overload protector, the start relay, and on some models a start/run capacitor.
You can pull off these components, and have them tested at most appliance parts houses. If any check bad, replace.
If they check O.K. then it is a problem with the compressor, and you will need the services of a refrigerator tech.
P.S. If the machine is under 5 years of age, do nothing, The compressor is under warranty and you should contact the selling dealer.
Even if it is a start component, let them repair it, since that will maintain the integrity of your warranty.
Thank you for using FixYa
Jan 13, 2010 | Refrigerators
BARLEY COOLS COMPRESSOR WILL KICK ON AND RUN FOR 5 SECONDS AND KICK OFF EVERY COUPLE OF MIN THERE IS NOTHING ON THE COILS ANY IDEAS
Replace the compressor starter/overload relay. It's on or near the compressor. It will be making a click each time the compressor tries to start.
Nov 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor will come on for approx 3 sec and then go off with click and 8-10 sec. later try again
The start relay device on the compressor is faulty. replace this start device asap.
May 26, 2009 | Kenmore Freezers
Kenmore refridge/freezer does not cool at all.
did the tech try replacing relay and overload on compressor before he said it was bad?if not you may want to try to replace the relay and overload on compressor.very easy to do,but you will need to call your local appliance parts store with model # and parts are pretty cheep.wont hurt to try if he didnt.good luck
Mar 25, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
