Question about ViewSonic VA1930WM LCD Monitor
I am using VA1903wm LCD monitor from Viewsonic. It worked well at its non standard resolution of 1440*900 when used with Windows Vista. i had to upgrade to Windows 7 Enterprise edition and this resolution of 1440*900 is unavailable with Windows 7. My display resolution is now at 1400*1020 at 32-bit colors . This leaves the display showing blurred characters. I tried multiple times installing the Vista driver for this monitor as an equivalent Windows 7 driver was not available. How do I fix this problem?
  • 64 Answers
Update your graphics card drivers to the newest ones available. That is typically caused by having the default windows driver for your graphics card. If it is a Nvidia gpu get the drivers from them, itf its an ATI/AMD get them from AMD Game. If it is neither of those Intel does some graphic cards, if its not an Intel one go to the computer manufacturers website and find your model to get drivers for it.
Posted on May 17, 2011
I bough the LCD model VA2231w- LED every time I turn it on then it pop up that change the resoluyion to 1920/ 1080P I don't know how to do it. So please help. Thanks Thai Nguyen
This would be the Native resolution. That your display functions and displays best in.
Windows XP, Vista and Windows 7.
(1) RIGHT mouse click over your desktop.
Windows XP will differ - but same basic idea to navigate and make this fix.
Pictures show from a Windows Vista Machine (extremely similar to Windows 7)
(2) Click Display settings
(3) Now you'll see a slider bar, Native Computer Display 1680x1050 resolution.
Some computers can not support this resolution and may cause non operational situations.
If the display setting is not on the slider bar. Chances would be that it's not a supported Resolution.
"Older computer" If the display doesn't show while trying different resolutions - do not click apply and wait. the screen will return to it's previous setting. ViewSonic VX2235 has a Setting that could be used to Disable this annoying message - Revert to ViewSonic lightdark_2.jpg
Nov 15, 2010 | ViewSonic VX2235WM Monitor
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
Resolution problem
You need a separate card. I had this problem last week. My card cost $74 and everything works great.
Mar 24, 2008 | ViewSonic VA1930WM LCD Monitor
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Aug 13, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VA1930WM LCD Monitor Logo
258 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
