Question about Iomega 1TB Home Media Network Hard Drive (34337BN)
I installed the Iomega 1tb Home Media Network Drive on my network yesterday and it published itself. I enabled the port forwarding on my netgear wireless router. I then set some files to copy to the Hard Drive overnight. I noticed the copy did not work and it froze. I switched off the Hard Drive and disabled the port forwarding on the router. I have uninstalled and reinstalled the HMNHD software and turned off the Hard Drive and reset it many times but it doesnt have the white light on for longer than a minute and doesn't publish itself on the network. Unsure of what to do next? Frazzled
  • 4,281 Answers
Check tcp ip settings of your harddrive. Make sure it is in the range of your local network. check the ping command from computer if you get reply then it is in network. Then you can use it. Make sure network cable is fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 17, 2011
Boot device not found
Dear User...
The Iomega Home Media Network Hard Drive is born to enhance your digital life. you know attaching extra drives to the USB 2.0 port.
If any types of problem create then flow step.1> Proper USB driver installed.
2> You connect only back to cabinet. not to front side USB port.
3> If USB not connect that time go to my computer>property>hardware>device manager and see you USB port working properly or not.
4> Uninstall driver and restart computer. then again start computer and reinstall driver.
I hope solve you problem..
more info visit Techsupportmart
Jan 02, 2013 | Iomega 1TB Home Media Network Hard Drive...
No connection after firmware update
Ask for help here http://www.iomega.com/support
Or if you need data recovery help. These guys do it remotely http://FreeDataRecovery.us
Aug 12, 2012 | Iomega 1TB Home Media Network Hard Drive...
Possible ip conflict
Sounds more like a bad ethernet cable or bad port on the Iomega. Try using a different cable
Jul 20, 2017 | Iomega 1TB Home Media Network Hard Drive...
Iomega homwe media network drive - How do i map the drive? The Iomega Home Storage Manager is buggy and often canot find the drive.
Simple type the Ip address of the NAS Drive in the RUN window of your windows pc and hit enter.
Now all the shares appears right click the Share u wish to MAP and select MAP network drive.
That is it.
eg:in run type \\192.168.10.177 then replace the 192.168.10.77 with your address.
Jun 08, 2011 | Iomega 1TB Home Media Network Hard Drive...
My iomega network drive just decided to not show up as connected to my computer anymore. according to my router there is a physical connection, but my compy doesn't see it and the iomega software can't...
Reboot the network drive and the router, this usually works when mine doesn't show. You may need to disconnect any mapped drives, as it may show with a new ip address. Computer may also need to be rebooted.
Dec 07, 2010 | Iomega 1TB Home Media Network Hard Drive...
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
I have just bought an IOMEGA home media network hard drive 1tb and started the install. Before the install completed I encountered the blue screen of death, which identified the file QsFsFltr.sys as the...
Yes, I just had the same problem. All you need to do is go to safe mode on your computer, search for the file "QSFSltr.sys" and delete that filthy *******.
From there you have too choices. 1: use your warranty to get the money back for the **** you bought, with no ability to get support from the company.2: Use it, and don't download any of iomegas software in the future. (can still be used as plug-and-play)
Nov 24, 2010 | Iomega 1TB Home Media Network Hard Drive...
I have a brand new Home Media network drive that wont install
Iomega Home Media Network Hard Drive User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hmnd/211-1009/en/index.html Downloadable User's Manual [232KB zipped HTML] http://download.iomega.com/manuals/hmnd-1009/html/en.zip Quick Start Guide [PDF 1.3MB] http://download.iomega.com/manuals/hmnd-1009/print/d31497002.pdf Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=20851&p_sid=V_3q12dk&p_lva=14432 ---------------------------------------------------------------------------------------------- Download the latest Manager software. Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
Sep 27, 2009 | Iomega Home Media Network Hard Drive 500...
Iomega 1TB Home Media Network Hard Drive (34337BN) Logo
478 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
