Question about Garden
Need programming instructions for a PYZ4 output transducer.
What is the function of the transducer? Stuck in "Limp In Mode"
A transducer is a sensor that does not need to make physical contact with what is is trying to sense. It can be used to detect the presence or position of something; on boats they are used to sense the distance to the bottom to determine the depth of the water.
These devices are typically employed to provide feedback - or "prove" that a command has completed or component is in the right place ie: A command to shift from position "A" to position "B" will be halted when the transducer at position "B" detects the presence of the shifter.
If the transducer is unable to detect the shifter at "B" or falsely detects that the shifter is always at "B" - it can cause problems. The device (computer or controller) that interprets the transducer output has no way of knowing if the shift has completed or not and can decide do something to limit damage to the motor, transmission, etc.
Here's a video that details the fix for your code on a Chevy Lumina
https://www.youtube.com/watch?v=NaLrsuRnLww
Dec 02, 2014 | Cars & Trucks
Installing transducer
I assume you're talking about a transom mount transducer. Best if the leading edge of the transducer is even/level with the hull and tilts slightly down in the back or trailing edge of the transducer. Also try to eliminate a gap between the leading edge of the transducer and the hull.
Mar 25, 2014 | Hummingbird Boating
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
Cuisinart coffee maker, how do I get the alarm NOT to beep when coffee is done being made?
Julie, I know EXACTLY what you mean. I hate getting screamed at in the morning "YOUR COFFEE'S READY!!!". Frig, i have small kitchen, you don't need to yell at me Cuis'. I couldn't even find the place where sound was coming from in order to cover it up.
Did you find a quieter machine? If so, what was it?
Mar 03, 2012 | Cuisinart DCC-1200 Coffee Maker
I have a new unit to fit. Can the transducer be mounted inside the hull? It currently gives me strange readings whether inside or out but we are on dry land - if that makes a difference
there are two kinds or transducers out there on the market --- some that can be mounted inside the hull and others that need to be mounted on the outside of the hull, the instruction manual should indicate which transducer you have. AND YES the transducer will only work when you are on the water --- the readings on land are no good and it will not work. install it on the boat and then test the unit on the water. BUT if you do want to test the unit before you install it to the boat you can always take the boat out to a lake ( or wherever ' on the water ' ) and mount the transducer to a long dowel or stick and hang it over the edge of the boat and this will work fine for testing.
' fish on and have fun '
c...
Dec 31, 2010 | Eagle Cuda 242 Fishfinder
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
