Question about Maytag Neptune MAH5500B Front Load Washer
When my washer is in the spin cycle, it has begun to spin very fast. It is about 10 yrs. old. The sound that it makes is extreme and frightning! should I be concerned?
    Problem Solver:
  • 17 Answers
Yes, I believe that the sound that you are hearing is often described as a jet taking off. If this is the case, start saving for a new washer because the repair bill will often be just as much.
What I believe you are experiencing is the tub bearing gone bad. What happens is that the shaft that holds the stainless steel basket where you place you clothes has a shaft that comes off the back and goes through the outer tub (which is plastic and holds the water). Where this shaft goes through this plastic tub there is a bearing. This bearing is protected by a seal that keeps water from escaping along the shaft. When this seal fails the water travels along the shaft into the bearing where it washes out the grease and rusts. Causing a loud noise when it spins. This can go on for months this way however, eventually one of two things will happen. The seal will fail completely allowing large amounts of water to escape (all over your floor). The second option is that the bearings will seize up completely and your washer will not spin the water out of your clothes.
Sorry for the bad news. However, if you don't think the problem is what I described please get a second look.
Posted on May 17, 2011
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Broken agitator kitchenaid washer
sounds like a trans coupling fairly easy repair shoudn't be more than 200 to fix
Mar 30, 2010 | Washing Machines
Our LSR7233HQ0 washer is 10 yrs. old and the agitator stopped spinning. Any repair tips?
You may have broken the drive belt. Can you hear the motor spinning still? If yes, then it is definitely a broken drive belt.
Oct 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
At spin cycle pump only runs for 3 seconds then stops
Sounds like the pump motor is overheating. Probably need a new one.
Feb 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Kenmore Elite Heavy Duty Washer
Whirlpool is still made in USA, I think. Avoid electronic timers and geegaws you don't need.
Dec 22, 2007 | Kenmore Elite 45986 Front Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
