Question about Kenwood Audio Players & Recorders
The receiver is flashing. Protect. And it want turn or program a station, what's. Wrong. With it
    Brigadier General:
  • 8,546 Answers
If it won't turn it won't do anything else.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 17, 2011
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
I have a TX-DS787 Onkyo receiver and the word
you have something hooked up wrong it dose this to protect the unit from burning up(shorting out)
Sep 07, 2014 | Audio Players & Recorders
How do i set the music stations
Turn on the desired radio station, press and hold the '1' button till you hear a beep. Now this station is programmed on this button, till you remove the +12V Memory wire from the device. On kenwood devices it is the yellow wire on the main connector.
Mar 13, 2012 | Kenwood KDC-138 FM / AM Receiver
Can't transfer recorded program to flash drive
Have you followed the manual, page 64, exactly? Open File Manager, select Copy, select the file from the hard disk and the destination - the flash drive.
If yes then either the flash drive is too small (a single film file needs at least 2GB of free space) or something is wrong with the drive:the format is the wrong one (it must be FAT32) or it's write protected - get another one and try again.
Jul 20, 2011 | Humax FOXAT HDR DTV Receiver
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
Dec 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Radio stations
tune in to station you like hold down button 1 till it beeps or flashes the beep or flashes lets you know its stored change the tuner and press button 1 on unit and it should go to the station you just programed (do same steps for all other button numbers.
hope i helped
Feb 28, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
47 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
