Question about Whirlpool Dryers
I want to know if my dryer has a pilot light to light.
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 17, 2011
Gas dryer pilot light
Hello Lara. Your dryer does not have a pilot light. It uses a hot surface ignitor to ignite the gas. Unplug the dryer and cover it with a plastic sheet before fogging.
Jul 08, 2016 | KitchenAid Dryers
Does a ge gas dryer with the model number DBSR453GBOWW have a pilot light?
Your GE dryer does not have a pilot light, a common issue on gas dryers is the ignitor. More info needed (what does the dryer do or not do when you push the start button?) to give a better answer.
Feb 12, 2015 | GE Dryers
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
How do you light a pilot light for my GE gas dryer? Model = DDG7188PHLWH
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
May 20, 2010 | GE Dryers
Gas Dryer DLG5966W pilot light
The power should turn on a electric igniter once the gas has reached the heat chamber and regulator. If not let me know soon the model number of your LG dryer so I can help you better, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 09, 2009 | LG Dryers
Gas dryer Maytag model # LDG410
You don't light the pilot. Gas dryers have a glow bar type ignitor. These get very fragile with age and will burn out like a light bulb. The other thing that will wipe out the glowbar is moving the machine if it gets handled roughly.
Jan 02, 2009 | Maytag MDG7600AW Gas Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Pilot Lighting for Neptune Dryer
there is an electric igniter but no pilot light in the Maytag 5500 gas dryer. you can change it yourself.. let me know
Aug 23, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
