NO AUDIO, NO SOUND CAN HEARED SPEAKER NOT FUCTION
  • 75 Answers
IF YOU HAVE NO SOUND DRIVER GO TO MY COMPUTER MANAGE DEVICE MANAGER CLICK ON DEVICE PROPERTY WHOSE DRIVER ARE NOT FOUND COPY DEVICE ID CODE OPEN http://devid.info site DOWNLOAD YOUR SUITABLE DRIVER AND ENJOY ANY BRAND AND ANY DEVICE DRIVER TO USE THIS SITE
Posted on May 17, 2011
Sound problem toshiba satellite C640,sound driver was okey.External sound speaker and microphone were okey but internal sound can't be heared
Hi bbasuki48,these instructions will help you with the "Audio / Sound problem. Part (1) Click on the "Start" button, go to and click in the (right, pane)Control Panel. Scroll to find, "Hardware and Sound."Next, click on the "Sound" applet!Select the "Playback" {Tab} at the top of the 'window'.Next, click on the Active "Speakers." icon.Click "Configure""Audio channels"The (Speaker Setup) "wizard," appear! Select (Test) click, Next!Follow the instructions.Click on the "Apply and OK" buttons, once finished. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. "The (Advanced), "not recommended!"In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (Enable) if not? "Change it." *Note: "Click on the Apply OK buttons; this will 'Save' the changes." Feedback: "Helpful Ratings" appreciated! Thanks, paul7of9"
Oct 01, 2011 | Computers & Internet
When switched on a humming sound comes out of all speakers,no audio can be heared when a cd is played.
check all jack plugs are in the correct places and speaker connection wires too.try turning your tuner on to test the speakers that way for sound,if sound is heard through the speakers it could be a cd malfunction.if nothing works contact your dealer.
Sep 03, 2011 | Eltax Nova Theater System
No Volume. Mute is not on. Volume control is at normal level. Tried leaving the TV off for awhile but still no sound.
Hello
If there is no volume in your TV, and mute fuction si in off position, and the picture is ok. there are two possibilities. The first one is, speaker of your TV is damaged. The second one is audio output Ic in your TVs inner circut board failed.
You just open your TV taking after every prcautions when we take before working with an electrical equipment. Keep children away from you, and let an adult beside you. Plug out your TVs mains chord out of wall socket, and never use a matal chair or a chair fabricated with metal. Do wear a rubber or plastic shoes, and not try to work with bare foot.
At first be sure whether the speaker is out or not. It can be tested without opening your TV. I suggests these, keeping in mind that your TVs picture is Ok. If not the problem may differ. Keep your ear very near to the speaker side of your TV, and swith it on with mains supply, and listen there is any sound or just a "thumb" sound is heard from the speaker. If there is no "thumb" sound, surely the speaker is damaged. Replacing it with same type and impedence [ie 4 ohms, 8ohms, 16ohms etc, will be marked on its magnet], will solve your problem.
If there is no sign or any sound, or just a "Hum' sound is prodced, the audio output Ic of your TV is damaged, or it is not getting the proper supply voltage to the respective supply pin. If there is a "Hum' sound produced from speaker, it is clear that your TVs audio Ic gets voltage, but it has damaged.
To repace it, you just follow, the two wires to your TVs speaker. It will go to the main board of a sub board which audio Ic is fitted. Normally this Ic will be screwed into a metal heatsink to runout the heat generated from it while working. Just desoder it, unscrew and take it out. Go for the same type and number. "Insist on same type and number. never try to use any substitutions, as it may effect the quality of sound". Solder it to the point. That is all.
Wish you success
If you have any further doubts, report to Fixya. They will send me alerts. Ok
Oct 21, 2010 | Zenith C27A24T 27" TV
No sound heared from speaker
Try reinstall your device(Sound driver which is provided with motherboard) driver Or
your Device got fried and you need to replace it.thanks
Jul 28, 2010 | ASUS P4P800-X Pentium Motherboard
15 subwoofers play in an out
the voice coil connected to speaker terminal of your speaker is partially cut but when the speaker has a music it will sound on and off....it will located in cone of your speaker..wire cutoff but sudently connected but when you apply a music ..on and off music will be heared..
May 25, 2010 | Car Audio & Video
Pc to pc talk my voice heared very low(input voice low)
you need to install the smart audio driver 221 for your laptop the mute problem should be solved with that and should increase voice qty a little. I guess you are using Win XP
Jan 26, 2009 | Compaq Presario Notebook
My computer audio sound is not working
u need to do this u have reinstall your sound driver from *********** bord cd
Jan 22, 2009 | Computers & Internet
Audio
sir my sound drivers are deleted and no sound heared on my laptop
May 29, 2008 | Computers & Internet
Unexpected problem
I think you can have problems with the speaker, if you see the signal display working when you reiceve the VCO is working. If you could check (I dont remeber if this radio has audio connectors) external speaker. If this radio has an audio conector, this conector switches the internal and external speaker and could be dirt and is not switching to the internal spk.
Jul 29, 2007 | ICOM Informatique Icom Radio U16, IC2GAT,...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
