I cannot read dvd in my combodrive, my friend informed me that lens has damaged. so i want to any their is any software 0r solution to repair the lens.
  • 670 Answers
The lens can be cleaned by a lens cleaner however there is no software that can fix it. Mostly if the lens is damaged the combo drive may need to be replaced. However, if you are comfortable disassembling the combo drive you can replace the lens on your own.
Just have to know what Number/Type is the lens and you can buy a replacement and then you can open the Combo drive and replace it.
If you are not very familiar with disassembling a combo drive I suggest that you just have it replaced.
Posted on May 17, 2011
Lost the piece that fits over the lens, won't start the dvd.
Possible that the optical head is damaged and so might need a replacement. If the piece you mentioned has come off the optical unit then the unit is damaged and will not read or pass on information to the processor to run the disc..
Jul 03, 2012 | Insignia IS-PDO40922 Portable DVD Player
Hi there, Our DVD S27 has stopped working. It doesnt read any DVD played. The DVD player displays msg NO PLAY. It used to do the same thing before couple of times and would then start working on its own....
Hi Parvana,
Try these basic steps below to solve your problem. You should prepare tools and test instrument like multimeter. If you can't do this yourself, I would advice you to find friends that can perform these guide.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 14, 2011 | Panasonic DVD-S27 DVD Player
Wii unable to read disc
If it is multiple store bought wii games, then your wii dvd drive will need to be replaced. Your other choice would be to mod the system and play games from a hard drive. Go to www.wiihdmods.com for free mod software.
May 16, 2010 | Nintendo Wii Console
Acer aspire combodrive
My guess is that your combodrive dosent suport the media you trying to play on it. I guess that is suports PAL and other media.
Good luck
Nov 26, 2008 | Acer Aspire 5100 Notebook
A friend gave us a dvd of a wedding. We played it on our player but ever since then the player won't play anything. It just clicks for several seconds and then an error displays on the tv that it can't...
Get a lens cleaning kit. Most likely some dust got on to the laser lens.
A non compatible CD or DVD disk cannot damage a CD player. There is no actual physical contact between the disk surface and the laser unit.
By coincidence, the player may have failed.
Jerry G.
Jul 19, 2008 | Televison & Video
Cd reading problem
The answer on the LG-site (mailcontact): Go to your dealer.
I think that a new one is cheaper than repairing my combodrive ( 2 yrs old).
P.S. : I'am the guest posted on nov 04
Apr 16, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Durabrand DUR7 Portable DVD Player
DVD player
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
Feb 09, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Won't play dvd
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
Feb 09, 2008 | Daewoo DVN8100N DVD Player
Dvd won't read
My friend this could be caused by many things everything from a dirty OR damaged disk, or wrong zone or wrong tv mode disk ie, NTSC instead of PAL OR VICE VERSA! Or the laser unit could be stuffed or a cable connecting the dvd drive to the motherboard could be broken or out of place. Or the reader lens could be dusty or dirty. Some DVD disks need a damn good clean with warm soapy water to have any cleaning effect. clean and reins like you do the washing up! Check these things first. A word with a friendly local tech is the next step.....but we all know thats a money trail often more than the cost of a chepa new player!
Sep 08, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Computers & Internet Logo
David Payne
David Payne
