Question about Car Audio & Video
I need an instruction manual for a VDO CD 531 B fitted in my 2002 golf gt tdi please
  • 84 Answers
SOURCE: how do you change battery in key fob on 2002 vw golf
No problem. The key fob is two pieces. The key part and the remote. Open the key as you would to sue it. Where the key flips open you can see a small recess about where the line of the trunck switch. This is where the key separates. You can pull it off or pry it with a small screwdriver. Once separated with remote part in your hand this also splits in 2. In the same area you split the key off insert the screwdriver in this recess and the fob will open giving you access to the battery. Also can be done by hand. It is a little tight so you will have to force which is normal. No screws just clipped. Make sure the battery is positioned in the right way and that you have 3 volts when you test the battery. 2.7 volts will make the remote not work or act funny.
Posted on Nov 01, 2008
greesemonkey
  • 67 Answers
SOURCE: golf gt tdi starting problem
believe it or not but i have seen a intermittant brake light switch cause that.
if you have a scanner monitor IAT ECT FUEL temp,when cold not running they should be with in 5 degrees from one another
Posted on Nov 30, 2008
SOURCE: my golf gt tdi glow plug light keeps flashing
check to see if your brake lights are working.usually the stop light switch fails and is the cause.but before buying a new one check the stop light fuse.its a common problem with a simple fix.hope this helps.
Posted on May 19, 2009
ElDopa
  • 295 Answers
SOURCE: golf gt tdi 2.0 140 bhp mk 5 - esp light
When there's something wrong with the brake pressure that handbrake warning light comes on.
The ESP warning light could be caused by a lot of things, but most likely it's a dirty fuel filter. Don't take my word for it though, just go to the VW dealer and have it read the faultcodes from the ECU, which should point you/them in the right direction.
Alternatively, when you have the right equipment (= VAGCOM + cable) and knowledge, you or a friend yould diagnose the ECU yourself.
From the sounds of it, you'll need a small service (air filter and oil filter change, etc.) anyways. Don't forget to reset the ECU (or dis- and reconnect the battery) afterwards to erase the faultcode from memory (when there's still something wrong, it'll return soon enough).
You might get lucky with a small service :)
Posted on Aug 17, 2009
  • 14036 Answers
SOURCE: I have a VW Golf gt tdi 150 bhp, my glow plug
most time when glow plug light come on your glow plugs not working.check fuse if fuse is good problem is in glow plug relay.
Posted on Dec 09, 2009
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
Dec 21, 2010 | Volkswagen Golf Cars & Trucks
2002 '51' golf gt tdi 150bhp, starts first time when cold and then after about 2 minutes of driving cuts out and takes a few minutes to start again, feels like diesel starvation. any ideas??
have you replaced the fuel filter? this is the biggest cause for these type of problems. one time i have seen the pickup fuel pump go bad though.
Mar 23, 2010 | 2002 Volkswagen Golf
I have a VW Golf gt tdi 150 bhp, my glow plug light has just come on.. Please can anyone help.
Dec 09, 2009 | 2002 Volkswagen Golf
How to fit brake pads front+rear on a golf gt-tdi??
I think that the caliper separates for the new pads to go on. Mike. Rate 100% and respond back please..
Sep 24, 2009 | Volkswagen GT Cars & Trucks
Owners manual 2006 gti se golf automatic
ebay is good source of used owners manuals
Jun 30, 2009 | 2002 Volkswagen Jetta TDI
Wing mirrors on 06 plate Golf TDi
Has it ocurred to you that your wing mirrors are not the electrically folding type, most are not. The switch on the drivers arm rest for adjusting the mirrrors will have a separate position for folding if yours fold. The resistance to fold by hand is very stiff as you have to overcome the spring tension, even when folded by hand they do not fold as flat as you might think.
I purchased a 2006 Golf 5 GT Tdi last year it had £5000 worth of factory fitted options but did not have electrically folding door mirrors - hope this helps.
May 14, 2009 | 2006 Volkswagen Golf
My golf gt tdi glow plug light keeps flashing
Apr 28, 2009 | 2003 Volkswagen Golf
Car Audio & Video Logo
284 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
