Question about Samsung RS2630SH Side by Side Refrigerator
Samsung frost free fridge freezer - RL39WBSW
Hia - my fridge freezer is making a loud noise - like a vibration and the frost free freezer is freezing up.
Please could you let me know if you know what the problem is.
Thanks in advance.
Claire
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE:
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
331 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
