I have attempted to print some photos - which I have downloaded to my computer - on a HP PSC1317 AIO printer. The problem is that the printing operation stops at around the half-way point with an E message on the machine. I have cleared the apparent jam and started all over again with the same result. I have tried various photo papers without success but found that I got a full printout when I used plain paper.
  • 4 more comments
  • 718435 Aug 14, 2008
    Solution did not work
    I have disconnected the power supply from the printer and waited five minutes as suggested.
    This did not solve the problem.
    I have earlier reinstalled the printer software
    I am using a lighter weight of paper (180gsm) than my normal paper
    I am using a thinner paper (180gsm) than my normal paper.
    I sorted out the problem in the end by using the photo paper recommended by HP
    Master:
  • 521 Answers
I too have faced the similar problem while printing photos few months back .some one suggested me to check the same printer with another pc to print the same photos fornunately i had other pc with a higher configuration then the first one.it perfectly printed while printing with the second pc.but still whenever i connect to my old pc it creates the same problem as before.i am not sure but i belive that it was may be because of the low configuration of the first pc which was not able to print the printout of the heavy load. documents print properly with both pc, but for photos everytime i need to use my higher configuration pc.this may not be solution for everybody but it solved my problem so i shared it with you, may be it helps you too.thanks. and good luck.
Posted on Aug 14, 2008
    Master:
  • 623 Answers
Make sure tha the thickness of paper is correct for your printer
  • 3,037 Answers
Make sure the printer settings on the computer are set for the kind of paper that you are using or at least set to a thicker type of paper.
    Genius:
  • 2,920 Answers
The paper you are trying to use may be too thick for the printer to pull through
    Genius:
  • 1,011 Answers
Dear,
what about its other function, mean scanning and other..
is it fine or causing some problems
if all are creating problem then check its proper driver here, or u can try on for this also.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&product=374584&dlc=en
regards,
  • SALMAN NASEER Aug 14, 2008
    by the way, try to print any small size photo with the same paper in which problem comes ...
    if it works with that then that can be caused by the ink catridges or it can be the fault inside the circuitry. Because for printing a photo or other, printer has to warm up and technically the printer roller has to charge for printing.. maybe for a big high colored photo can not be targeted by the printer. in this case u have to repair it either in warranty or without it.
    regards,
    dear,
    if u have any external memory card inserted then remove it and then make it on .
    maybe this is caused by that also..
    regards,
  • 13,433 Answers
Sounds like a driver problem, try reinstalling the drivers and software for the printer.
  • 19,396 Answers
Also disconnect power cable for 5 minutes, draining power off the printer will reset the unit.
  • Ginko
    Ginko Aug 14, 2008
    If it happens only when you print photos, then the problem is related to the bigger amount of ink required when printing pictures. Try lowering down print resolution in printer settings, this will set the printer to spray a smaller amount of ink.
    Also ensure you are using the right photo paper and that printer settings for paper are on photo paper.
    If the problem persist it can be a factory defect, Contact hp using the phone number printed on printer's user manual and see if they offer a replacement for your printer.
    Do not forget to vote the solution.
  • Ginko
    Ginko Aug 14, 2008
    I would exclude driver problem, as the printer prints well on any other format, it is either an ink/heads problem or a mechanic problem with photo paper jamming when print is half way through.
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 14, 2008
    turn printer off, take cartridges out, turn on , then turn off again, put cartridges in and print
    Lemme know
  • John Smith
    Why dont you repair it under warranty
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    I cant print photos from roxio why?
    Please download the Kodak aio home center software on your computer.The printers are compatible with every software but we have to make certain changes in a software to work with the printer.Try to print from other applications after installing the software..
    Dec 30, 2009 | Kodak ESP 5 Printer
    Dell Photo 966 AIO won't print after trying to download Adobe 9
    You need to restore your computer to a date previous to your Adobe 9 install. Click the following:
    Start-Programs-Accessories-System Tools-System Restore. Choose an available date prior to the date you installed the problematic software.
    Nov 07, 2009 | Dell 966 All-In-One InkJet Printer
    HP C4280 does not scan
    Hello !
    Your print driver may be corrupted. So, give this a try:
    Delete your AIO icon from Printers and Faxes
    Download the latest driver for your operating system from here:
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3192753&
    Disconnect your USB printer cable
    Restart your computer
    Reconnect your USB printer cable
    Your computer should see your AIO and install the new driver.
    If your computer does not see your AIO, your USB printer cable is faulty or try another USB port on your computer.
    Hope this helps.
    Sep 16, 2009 | HP Photosmart C4280 Aio Printer
    Dell AIO 942 Printer - updated driver from Microsoft
    In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
    Good Luck........
    Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
    HP C6180 won't print borderless photos
    Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
    Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Hp 1115 photosmart dics to load to computer is broken
    Hello there.
    You can download the setup files from the Internet by clicking here. Choose which version of Windows you have, then click on the "HP Photosmart printer software/driver" and "HP Photosmart Essential Software for Photo Editing, Printing, and Sharing". Open the printer software when the download is complete and it will set up the printer, once that is finished then open the Photo Editing software (second download) and you should be good to go.
    Hope this helps.
    Apr 14, 2008 | Office Equipment & Supplies
    Dell AIO 926 printer
    From the following link download the Dell printer uninstaller
    http://tinyurl.com/29z5yr
    R166248.zip. extract the file and Run the wizard. Make sure that the printer is not plugged in when the wizard is run.
    Restart your computer, Install the latest drivers .
    If you are not able to install the drivers or your printer is stilll not printing its time to reinstall windows.
    Thanks
    Mandeep
    Apr 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
    No driver on hp 3745
    if needing a driver for printer pop in to hp 3745 and get them from here .
    best of printing .)
    riz.
    Feb 23, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Printing black squares in word.doc
    It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
    Apr 11, 2007 | HP PSC 2410 All-In-One InkJet Printer
    47 people viewed this question
    k24674
    jasbo
    jasbo
