Question about RTO Neat Receipts 00315 NeatDesk Desktop Scanner & igital Filing for PC
Is NeatDesk compatible with simply accounting
Neat multi-page
The neatdesk software allows you to rotate the image as desired. Pay close attention to how you load the documents to determine the correct way to load.
Sep 05, 2014 | The Neat Company Neat NeatDesk Desktop...
NeatDesk scanner
paper feeds on printers and scanners can be seriously damaged by thick paper jams. Aside from actually taking the unit apart (which can be daunting) try sliding heavy card stock through the paper path. Don't force it. Sometimes cutting it into a narrow strip (3 or 4 ") helps it slide through.
Mar 05, 2014 | Neat Company NeatDesk Scanner
Manual for neatdesk scanner
Checkout the available downloads and video tutorials from the link below:
www.neat.com/support/video-tutorials-and-user-guides
Hope this helps.Thanks!
Jan 05, 2012 | RTO Neat Receipts 00315 NeatDesk Desktop...
Hi i'm trying to find out is simply accounting and NeatDesk scanners are compatible. What i am looking for is a way to scan a invoice file and import the information into simply accounting with out...
There is no scanner invented yet which can create a file that can be read completely read by accounting software like excel because the file that is created is an image file whose individual data like numbers and alphabets could be read by the most up to date accounting system. The only solution I see is that a data entry operator has to manually enter the data in the computer system.
May 17, 2011 | Computers & Internet
I have simply accountinfg 2004 My computer crashed, and they fixed it for me. The person who has trapair my computer put windows 7 . First I had windows xp. All my files are in the computer, I see...
You will probably need to upgrade to a later version of the software that is windows 7 compatible.However try running the program executable (the main file that opens the program) in XP compatability mode, that sometimes works.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | ACCPAC Simply Accounting 2004 PRO...
Trying to install neatdesk and it come up saying,. config.nrcfg is denied what to do?
It sounds like you don't have sufficient access to install this software. I am assuming you are installing from a CD here so here is what I would do. I would Right click on my CD Drive and click Open and look for the Installer for the software you are trying to install. Right Click on the Installer (May be named Setup.exe, Neatdesk.exe) and select Run as Administrator and that should give you sufficient access to run the setup for your receipt scanner. I hope this has helped you some.
Ryan
Feb 23, 2011 | RTO Neat Receipts 00315 NeatDesk Desktop...
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
How to instal Simply Accounting 2002 on OS Vista
Hi iberlinson,
Simply Accounting 2002 may not be fully compatible with Vista. The 2008 and 2009 programs are compatible with Vista. You may want to try installing outside of C:Program Files if possible and make sure you save your Simply Company files outside of this location.
If you have any further questions, feel free to visit the Simply Accounting Online Community at: www.simplyaccounting.com/community
I hope this helps!
Andrew C
Simply Accounting Support Analyst
Mar 14, 2009 | ACCPAC Simply Accounting 2004 PRO...
RTO Neat Receipts 00315 NeatDesk Desktop Scanner & igital Filing for PC  Logo
276 people viewed this question
Top RTO Computers & Internet Experts
Martin Murray
Frank Zabroski
Frank Zabroski
Robin Hill
Robin Hill
Are you a RTO Computer and Internet Expert? Answer questions, earn points and help others
