Question about Cameras
Need D70 Nikon software for my camera. Lost disk!
  • 313 Answers
Try this one and see if it works!
I hope I helped you!
Posted on May 17, 2011
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70 data imprint
Sorry for the long answer, but this is complicated.
Some photo editors will allow you to set them up to display the date on the photo.
HOWEVER on all digital cameras:
The date taken is part of the image data that is stored in the file, but not as part of the image. If you print directly from the D70, you can set the date and data to print in one of the menus, but this only applies if you print from the camera. There is no way to actually put the date on the image like there used to be in some film cameras. Since the "picture" is now just a set of computer data bits stored on a card, disk, or other medium, the actual picture is defined by the jpeg standard, which is part of the ANSI/ISO/IEC organization. A camera manufacturer could add an extra bit of hardware to generate some kind of laser mark on the digital sensor in the camera, but I'm not aware of any camera that has this. For sure, the D70 does not.
In the various softwares that you can buy to read the file, the information in the file (like the date) can be interpreted and printed any way the software is programmed, including putting it somewhere on the printed output.
Aug 27, 2009 | Nikon D70s Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
Nikon D70 Shutter Problem
I have a Nikon D70 which failed completely but exhibited similar symptoms.
I was fortunate in that I had taken out 3 years free warranty at the point of purchase and therefore saved the £90 (sterling) repair cost.
Nikon cameras are designed to be robust and should give a lifetime's service. Most should give 150,000 shutter actuations.
There is a piece of free software available on the Web that will tell you how many actuations were recorded on your recent photos.
Unfortunately, in the fast moving world of digital cameras, the value of a 2nd user older camera is very low.
You need to decide if you were outgrowing this camera body and want to replace it with something better or whether you would be lost without it. My repair took more than 1 month and I was not able to take any photos during his time.
I hope this helps.
Jan 15, 2009 | Nikon D70s Digital Camera
D70 will not connect to
I checked all connection and cables and found two issues not related to camera. The USB cable was faulty, replaced and I could connect to computer through F port but the J and I port of the computer continues to not respond and I will need to see what is wrong there.
Mitch
Oct 04, 2008 | Nikon Cameras
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
How can I use the Adobe Camera Raw plugin after installing Nikon Software?
During the installation of Nikon View or Picture Project, your system is checked for an installed copy of Adobe Photoshop. If a copy with the minimum version is found, Nikon View will install file format filters which will allow Photoshop to open a NEF/RAW file directly (there are other plugins for YCBCR TIFF format from supported cameras). If you have the Adobe Photoshop "Camera Raw" software installed (optional in Photoshop version 7, included in Photoshop version CS) the Nikon file filters will open the file. If you prefer to continue using the Adobe software, find and remove the following plugins: Nikon NEF Plugin (Nikon View) Nikon NEF Plugin LE (Picture Project) After a restart of Adobe Photoshop, the Adobe Photoshop "Camera Raw" plugin will handle the opening of Nikon NEF/RAW format files. Please note that there was an update for Adobe Camera Raw plugin for support of D70 and Coolpix 8700 RAW files, if you encounter difficulty opening raw files from any Nikon product after removal of the Nikon Plugins, please visit the Adobe support site to obtain the appropriate update for the Adobe Camera Raw plugin.
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
