Cartridge refill is not working - Office Equipment & Supplies
  • 75 Answers
If you have inkjet printer cartridge and you are refill it and it,s not working put one by one in lightly warm water for some time after some time use this cartridge this solution are mostly worked for inkjet printer cartridge
Posted on May 17, 2011
The colored ink cartridge was refilled once and it worked well, now I'm refilling it the second time and it seems to not be responding anymore, assistance please, if there is any.
It is not recommended to use the refilled ink cartridges...But anyhow you can use the refilled cartridge once or twice if it is refilled properly...
When refilling the cartridge, the cartridge will be opened for refilling the INK...In this phase the Circuit in the cartridge may be damaged due to improper handling...
In this situation the cartridge has to be changed, No other go...!
Feb 24, 2011 | Lexmark Z640 InkJet Printer
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
818 cartridge refilling
If you mean the HP DeskJet F380 cartridges (the HP 21 and HP 22 cartridges) you will have unreliable success refilling these cartridges either yourself or online, at Costco, Office Max, and Walgreens. These refillers generally don't have fantastic quality control or knowledge of printer cartridges. I suggest Cartridge World or Office Depot refills. If you mean the HP Photosmart C8180 (the HP 02 cartridges) refilling them is easy but you need to replace the chip on the cartridge for it to work in your printer. As long as a refilled cartridge has a new chip it should work in your machine. Again I recommend Cartridge World or Office Depot refills.
Nov 24, 2009 | HP DeskJet F380 All-In-One Printer
Refilled my lexmark cartridges but still dont work
14 and 15 won't work after refill. You can only refill 14A and 15A.
But even when you refill those, the printer will keep telling you they are empty, which is normal, neither the printer nor the computer can know that you have refilled your cartridges. The devices see cartridges by their serial number, so it resets the counter only when you pop in a new cartridge. They are ways to bypass that by resetting the ink level: use clear tape over the left hand row of sensors on the front of the cartridge and re-insert it. The ink now shows with question mark but reads as full and prints fine. You actually "fool" the printer into thinking you have put a different cartridge. This works with some printers, so I am not 100% sure it will work with yours.
Oct 23, 2009 | Lexmark X2690 All-In-One InkJet Printer
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Oct 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
Refilling the Lexmark x5470 color ink cartridge: Can't
There should be a dialogue box that pops up on your computer when the cartridge is low telling you to order new ones. Usually there is a box you can check to tell it to ignore that the cartridge is low. If you don't get the dialogue box, somewhere in your printing preferences you should be able to tell it to "ignore ink levels." There does not exist a cartridge that "does not contain this circuitry." There are no compatibles of these cartridges and all refills are of original manufacturer cartridges.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
26 people viewed this question
jasbo
jasbo
