Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Hello i own the bissle proheat steamer it turns on but no water or soap or suction from floor or the utensiles ive taken the take off the back to scope out anything that could be in the way but dont see anything the motor is making that clogged vacume noise witch makes me believe something could be stuck somewhere in it but it could also be no water is getting to the pump or despencer but the brissels still work belt for that is good where would i be best to check and where is the location of these spots to check if i were to go ahead and repair this myself any tips are appreciated thanks
  • 8 Answers
SOURCE: bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Posted on Apr 01, 2009
SOURCE: My Bissell ProHeat 2x is pouring water out of the
Took the unit apart and discovered my heater had small pinholes in the metal and they had put in silicone, instead of a gasket, which didn't seal. So much for the place I took it to "saving" my heater for me. I repaired it myself by getting a few o-rings and a seal from the hardware store. As for the "holes" in the bottom - a little marine fixative.
Posted on Nov 05, 2009
  • 20 Answers
SOURCE: bissle vacume can not fit belt around motor
It sounds like you got a belt that was too small, if it is the right belt it will be hard to get on. But once its on you will be all set.
Posted on Jan 17, 2010
heatman101
  • 43501 Answers
SOURCE: Our Bissell Proheat began to make a strange sound
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell won't release soapy water solution
heatman101
hjf
Posted on Sep 30, 2010
No sign of water movement from cleaning heads
My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I can only use the ulpusltry attachment the floor cleaner does not shoot out any soap can the lines be clogged and how to unclog them?
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing. With the dial set to "Tools", I had the same problem.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW on carpet & tool settings. Don't know if this will help you, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x won't release soap water
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
No suction of liquid off floor.
This unit has to have some type of clogg in the hose or unde neath the unit. Check to make sure that you have suction in the hose first.
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 7901-1 steamer won't **** up the water
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap from dispenser will not release into carpet cleaner.
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Aug 13, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
374 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
