Question about Motorola Walkie Talkie 2-Way Radio
Broken antenna. Is it possible to reconnect the copper wire?? talkabout 250
  • Herbert Tarreyon
    Herbert Tarreyon Mar 30, 2016
    Sorry to hear of your broken antenna. This is no reason to discard the radio, however. This may be a good opportunity for you to do some experimenting. For example you may make an antenna repair by simply attaching a wire to the stub which is still on the radio with a small alligator clip. Begin with a length of 16 or 20 ga. wire about a foot long. Experiment with coiling the wire as opposed to using it straight. Try a piece of wire such as a coathanger. You will not harm your radio with this type of experimenting and it may be a period of enlightenment for you. Good Luck.
  • Motorola Master
  • 1,654 Answers
Sorry,but no. The radio is non-repairable once the antenna has been removed.
Best regards.
Posted on May 17, 2011
Is it possible to put a longer antenna on
yes, but no. The radio is designed for low power and a short antenna to limit range. This was to reduce interference with Licensed FCC radios. Since I will provide a few ideas, these are to experiment with radio waves, NEVER to break the law. So.....ideas to increase antenna: most simple, tape coax to the antenna lead. It will pick up a small amount of the radiated signal and sent it to the longer antenna. Strip the rubber and even the mesh, the center copper sends the signal. Best if under 10 feet. Other than this, you either cut open the rubber antenna or best of all, open the radio and soldier to the antenna connection on the main board. Remember: low power radios cannot send a signal far. Use good quality coax, RG58, never cable TV coax. Short length has a better opportunity of working. 30' you will lost all the signal in the coax. Other ideas? Yep, lots. email us. :)
Jun 29, 2015 | Motorola TalkAbout T5000 2-Way Radio
How to replace damaged antenna on the MR355R HT radio?
A replacement antenna is not available from Motorola for this model. The MR355R has a fixed antenna, and was not made to be removable. This being said, it is possible you could find a for parts only radio on ebay and disassemble it to remove the antenna for yours. Parts and schematics were never made available for the TalkAbout line of radios other than the TalkAbout Distance and Distance DPS.
Best regards.
Oct 18, 2014 | Radio Communications
Broken rubber antenna on Motorola talkabout 250
Parts are not available for this model. Your best options are to replace the unit or watch for a parts radio on ebay
Sep 07, 2013 | Motorola Walkie Talkie 2-Way Radio
Motorola talkabout fr 50 antennas are broken down how can I supply the antennas
Sorry, parts were not offered for this style radio. However, you might watch for used ones on ebay for replacement parts.
Best regards.
Aug 09, 2011 | Motorola Talkabout FR50 (14 Channels)...
Rubber antenna has become old and cracked and fell off almost both of my 250's exposing the coil wire antenna underneath. How to repair or buy another?
Many operators just wrap the coil with electrical tape. The antennas are considered to be non-replaceable, so they are not offered as repair parts. And if they were offered, they would probably cost more than new radios would.
Bill B
Apr 26, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Replacement connector for Sennheiser PX 250 doesn't work...
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
Oct 03, 2009 | Sennheiser PXC 250 Consumer Headphones
Antenna for a Motorola Talkabout 250
Get a plastic tube (3/8 PVC will work) and use it as a mould. Pump it full of black RTV silicone. Fixed!
Mar 25, 2009 | Motorola Walkie Talkie 2-Way Radio
On/off
The orange button on the right, below the antenna, is the on/off
May 21, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Radio Communications Logo
349 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
