Question about D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601
Electricity went out in my home and now my computer will not connect to the internet. I checked with my internet server and the problem appears to be with the router. I have a D Link N150 home router. Can you please email how to troubleshoot the router and get it working again?
    Sergeant:
  • 212 Answers
Ok...the first thing to try is to power everything down....modem, router, and PC.
Then power them back on in this order: Modem (wait for lights to go solid) then Router (again wait for solid lights) and then PC.
I am assuming you are trying to connect wirelessly. So if it's not working on wifi, try it plugged in using an ethernet cable. Make sure that the connection from your provider comes from the wall to your modem, then from your modem to router, and from the router to your PC.
If you can't get a connection wired, take the router out of the mix. Plug your PC directly into the modem. (rebooting them both in the same order that I mentioned above.)
If it works with the modem, then the problem is with your router. You may need to press the reset button for 30 seconds or so and start over with a fresh configuration. If the modem connection does NOT work, you may want to get on the phone with your providers support team to check the connection coming to your house.
Posted on May 17, 2011
How can I fix the error: "Proxy server not responding" on my Dell desktop?
Why are you running a proxy server? If you are on a home computer, sounds like a virus may be intercepting your traffic. Go into the internet settings and check the proxy settings. Write them down, just in case, then disable the proxy service.
Also, I'd install Malwarebytes to check for viruses and trojans.
Free Anti Malware Internet Security Software
Dec 22, 2014 | Dell Dimension Computers & Internet
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
Everytime i coneect to psn a error keeps comin up 80023121
This one is usually connection to the play station network problems, theres a few people with this today so maybe they are making some changes to the PSN servers it may well go away by itself. if not gone by tomorrow, check all you internet connectivity (ensure that you have a link to the internet on maybe a home computer).
Apr 21, 2011 | Sony PlayStation® 3 (80GB) Console
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
Can vista home premium connect to a LAN
You should check the possibility to connect to homegroup network. I have Vista home OS and I can use router to connect to internet but I can not connect to other PC runned windows 7, I can see them but without connection. I had found on a forum that Vista home version can not interconnect in homegropu network.
Good luck with your search
Mar 19, 2010 | Computers & Internet
Describe how to update blue ray player
Software Update Instructions
    • WARNING!! Do not power off the Home Entertainment Server or disconnect it from the AC power outlet. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • WARNING!! Do not press any buttons, except as instructed, until the update is complete. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • The software update process usually takes about 15 to 30 minutes, depending on system configuration and network connection.
    1. Power on the television and make sure it is tuned to the inputs to which the HES-V1000 Home Entertainment Server is connected.
    2. Connect the LAN terminal on the HES-V1000 to your Internet source using an Ethernet cable.
    3. Power on the HES-V1000 Home Entertainment Server.
    4. Press "HOME" to go to the Home Menu.
    5. At the "Home" menu, select "Settings".
    6. At the "Settings" menu, select "System Settings" and then press "ENTER".
    7. At the "System Settings" screen, select "Software Update" and then press "ENTER".
    8. At the "Software Update" screen, select "Network Update" and then press "ENTER".
      Note: The network connection display appears.
    9. Select "Yes" and press "ENTER".
      Note: The server starts to check the version information.
    10. At the version confirmation screen, select "Yes" and then press "ENTER".
    11. The software License Agreement appears. After reading the content, select "Agree" and press "ENTER".
    12. The software update is downloaded and automatically starts updating the HES-V1000 software.While the software update is downloading:
      • "DOWNLOADING XX%" appears on the front panel display, indicating the progress.
      • If the download fails, an error message appears on the screen, and the display returns to the Home Menu.
      When the software update is complete:
      • "VERSION UP FINISH" appears on the front panel display, indicating that the update was successful.
      • If "VERSION UP FAIL" appears on the front panel display, repeat the update procedure above.
    13. The system will power off automatically.
    14. Power on the Home Entertainment Server again.
Please refer the following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5321&mdl=HESV1000
Feb 11, 2010 | Sony HESV1000 200 Disc Blue-Ray Server
Outlook express - server pop needs to be changed. When I left embarq and went to Cablevision the server data did not change. E mail from computer generated from Outlook express does not generate.
You have to use your internet providers smpt-server.
This is something most internet providers forces us to do these days as a way to stop spam.
Either you contact your internet provider and ask for the correct smpt server, or you check their site. They usually have the right smpt server mentioned on their site.
Cheers
Apr 07, 2009 | Dell Microsoft Windows XP Home Edition
D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601 Logo
74 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
