Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Briggs and stratton 6.5 intek runs only if i keep priming carb
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Drain the gas. Remove the aluminum float bowl on the carburetor. Dont lose the exterior washer. Clean the brass bolt very well that hold the bowl on...paying very close attention to the small holes near the top of the bolt. Use no metal objects to clean this brass bolt as it also functions as the main jet to the carburetor. If you clean it till it is nice and shiny and reinstall it (not TOO tight) then your fuel flow problem may be resolved. Hint: Install an inline fuel filter.
Posted on May 17, 2011
How to keep engine running ?
Hi Doug:
I'd drain and clean the carb, using air to blow out (gently) all the orifices. If there is a filter, make sure fuel is flowing through it, or just replace it.
Should run like a good thing after that.
Cheers.
Apr 09, 2016 | Briggs AND Stratton Intek Briggs &...
Will only run on fuel that is primed into carb. briggs and stratton 6.5 i/c intek. already removed bowl and cleaned out varnish problem still exist
Check for proper operation of the float and needle. If that is okay, clean the jets and all holes. if the main jet is blocked or the holes going into you will not get it to start.
Jul 30, 2011 | Briggs & Stratton Garden
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 6.5 HP B+G lawn mower has gradually required more priming to start and now will not continue to run without constant priming. I have sisassembled the housing and found that the two screws that hold the...
remove the sediment bowl on the bottom of the carb and see how much dirt/contaminent is in the bowl,then lift the float (the metal or plastic round donut shaped object in the bowl) and see if gas runs out,if not then the carb is plugged and engine wont get gas to operate,then you need to try carb cleaner or a complete carb rebuild
Apr 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Oct 07, 2009 | Garden
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
846 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
