Question about Nemox Gelato Pro 2500 2.5 Quart Ice Cream Maker
The only problem is that its not getting cold enough to freeze the ice cream, ideas? already cleaned out the inside.
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Can you tell me how this ice cream machine works
The basic old style ice cream maker worked by putting the ice cream ingredients inside the center container and the motor device on top turns the spatulas inside to mix it up. Then you put ice and water and salt in the outer bucket. The ice and salt make it very cold so the ice cream freezes as it churns. Some newer devices, just have a mixer and you put the whole thing in your freezer to make it freeze.
Dec 11, 2014 | Ice Cream Makers
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Doesn't freeze consistently
    Here is a tip that will give you the information you are looking for...
    Ice Cream Maker Parts, Instruction Manuals and Recipes
    http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
    heatman101
    Jul 13, 2010 | Rival 8704 4 Quart Ice Cream Maker
    Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
    Welcome to FixYa
    An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
    Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
    Read Following ...
    • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
    • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
    • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
    • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
    • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
    I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
    OR click here
    Just Check this Link too
    Thanks for Contacting FixYa...
    Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
    Why is my ice cream not freezing, used it last winter, following the same recipe and instructions but it is a milkshake consistancy
    I had this problem when I decided the salt wasn't necessary on the ice that chills the container. The salt lowers the temperature so that it is cold enough to freeze the milk. Try more salt on it.
    Jan 06, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
    Wanting to make less than the 5 quarts that it holds, do I just reduce the recipe to the 2 quart instructions, will it freeze with that much less?
    Why would you want to do all that work for LESS ICE CREAM???
    In my experience, your ice cream maker will make any amount of ice cream up to its capacity. Remember, it is the salt that is the magic ingredient here ... that allows the ice water you are creating to get colder than 32 degrees F. Ice isnt really cold enough to freeze the mixture.
    Sep 07, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
    Sorbet not freezing
    If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
    Hope this helps.
    Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Undependable freezing - sometimes will, sometimes won't!
    High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
    -Tha Mp3 Doctor
    Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
    Ice cream has ice crystals in it
    Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
    Here are some of the useful tips:
    1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
    2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
    3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
    Hopefully this information helps a lot.
    Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
    Nemox Gelato Pro 2500 2.5 Quart Ice Cream Maker Logo
    49 people viewed this question
    Top Nemox Ice Cream Makers Experts
    Colin Stickland
    Colin Stickland
    ray gallant
    Are you a Nemox Ice Cream Maker Expert? Answer questions, earn points and help others
